Old 01-18-2006, 06:37 AM
High Pressure PS Hose
I just thought I'd let everyone know my new SVX had a REALLY bad PS leak from the high pressure PS hose (yeah the one RIGHT over the Pass side Cat ...made it smoke like a steam engine going down the road )....
Anyway to the point....
I had a local Car/Truck Parts place (that has parts for big trucks) rebuild the HI-side PS hose, cost me $35...MUCH cheaper than a new Subaru hose, and cheaper than a used one generally goes for
So, check out your local shops, might save you some money, as I knmow this hose is becoming an issue as the SVX gets older.
It is a bit of a PITA to install, but do-able....
Hope this helps some members who might have the same problem.
Old 01-18-2006, 08:26 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Thanks Huck! I also found a local shop that'll make s.s. brake lines that have metal bracket that don't heat up and break for about $75 for the set. Its amazing what you can find if you only know where to look!
Old 01-18-2006, 09:23 AM
dcarrb dcarrb is offline
Good tip. A nearby auto parts/machine/hydraulics shop made a high-pressure PS hose for my '68 Mustang years ago, and I'll probably go see the same guys the next time I need one on any car.
The Mustang's hose let go all over the exhaust manifold and, yes, PS fluid does burn. I resolved that day to start carrying a fire extinguisher in the trunk (but never did).
dcb
Old 01-18-2006, 10:06 AM
n00b on demand's Avatar
My HP hose leaks bad too. Theres damn ATF all over my engine bay on that side. Literally puddles after I drive
Old 01-18-2006, 01:28 PM
That's exactly what I did with mine. Not sure how much it cost though.
Old 01-18-2006, 11:38 PM
I'll look into that too. It beats the price that they get for a new one.
Old 01-20-2006, 07:09 PM
svxcuseme's Avatar
svxcuseme svxcuseme is offline
5 speed 4 sure
I paid for a new hose, from the dealer, before I snapped to my senses. Unfortunately it was too late. Having a hose made is definately the way to go.
