Old 12-12-2005, 09:51 AM
jman050's Avatar
jman050 jman050 is offline
Its a Classic!
water in spare tire well
My car was sitting outside for about 2 months while I was in college. My parents were starting it and letting in run occasionally to keep the battery alive and everything moving but they noticed that major condensation was building inside the windows. I figured It was the weatherstripping but I had taken out the back seat so my trunk was open to the inside on the car and when I checked in my spare tire well there was about 1.5 inches of water in it but the carpet covering was not wet at all. Does anyone have any idea where this water could be coming from?
-Thanks
[SIGPIC][/SIGPIC]
Old 12-12-2005, 09:54 AM
jman050's Avatar
Its a Classic!
Oh wait maybe I should have searched I guess this is a common problem But I read that the sunroof drain pipe should be checked.....where is this located?
[SIGPIC][/SIGPIC]
Old 12-12-2005, 10:32 AM
AFBeefcake's Avatar
Subaru Swapper
Allso check the tail light seals. Thats how water got into mine.
2005 Legacy GT
My WRX's Cardomain Page
Old 12-12-2005, 11:28 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Antenna drain too. You can always pop some of the drain plugs off until you find it.
Old 12-12-2005, 04:16 PM
All valid suggestions. It was the taillight gaskets and sunroof drain hoses for me.
Old 12-12-2005, 06:20 PM
Me too.
Old 12-12-2005, 09:55 PM
intelisevil's Avatar
<<<Alcyone
I was poking around in the rear of my 'new' '92 Ebony and found that I have the same problem, except with the temperatures we've been having recently it's a two inch layer of ice! The spare tire is frozen into place.
Dan
Pentiums - Melt in your PC, not in your hand!
Project - '92 Claret - Purchased May '06, 99,XXX Miles. Includes two bad engines and one bad tranny, cracked windshield, otherwise mostly complete.
His - '92 Ebony Pearl - Purchased Dec '05, 134,687 Miles. Parked, TC Seal(?) is leaking.Daily driver - 140,500 and climbing.
Hers - '92 Teal - Purchased Aug '05, 129,050 Miles. Daily driver - 160,000 and climbing.
PWR Radiator!
Problems:
Antenna doesn't work - Bought a 'new' one - Too cold to install . . . OK, it's warmer but I have other projects too!
Ticking from front of engine, passenger side - Stuck lifter?
Old 12-13-2005, 10:34 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
LMAO, that's not good!
My trunk filled with water because of the light seals and missing some light plastic part where the trunk door closes, all better now.
Still in love with my Subie
