Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
Old 12-07-2005, 10:50 PM
drivemusicnow's Avatar
Poor College Racer
Z32 Maf, injectors, programming, etc..
LAN... I've been wondering something for awhile, and *yes this is off topic... deal with it* (you can PM me the answer if you'd like)
I understand the basics of ECU decoding, however I in no way could do it myself. I've done some research specifically regarding the DSM ecu, and found how time consuming this process can be.
I'm not sure if you've looked into products such as "Hondata" and "DSMlink" however I was wondering if this was even in the realm of possible. (laptop adjustable E-prom. basically lets the end user control most aspects of the stock ECU. PM if you have any questions about the tech)
I know you probably don't want to put the time into it, as SVXes don't exactly have the most lively aftermarket, but if this was something that could be done with some basic programming and modified hardware, I think we could really get these cars preforming at a level beyond most peoples dreams. This would allow tuning with larger injectors, timing maps, really the possibilities are almost endless. Let me know if this is way out of our league as far as cost effective or even possible. Thanks
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-08-2005, 12:01 PM
longassname's Avatar
Just some dude.
It's out of the league of the current market that's for sure. Both in price and in doability. The svx ECU isn't as easy to tune as others out there. It's a better ECU than the others but it has more things that need to be adjusted when fuel injectors need to be changed. Some of these things are particularliy hard to adjust. I make a point of only releasing products that I am confident people will have success with and I'm confident end user tuning for the svx right now would be a dissaster. I think with the stage 2v5 software out now that we've met the needs of pretty much everyone for the time being. There are those who insist on trying other things but if they come around they will find that the stage 2 software is all they need. This doesn't mean end user tuning will never be. Should the community develop to where it's a viable product to release then I will revisit the decision.
Old 12-08-2005, 01:33 PM
AFBeefcake's Avatar
Subaru Swapper
The Z32 MAF will read 400HP of air right, so are the stock fuel injectors now the limiting factor?
2005 Legacy GT
My WRX's Cardomain Page
Old 12-08-2005, 01:40 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
From what I understand, your statement is correct. Even if fuel pressure is bumped up to 60psi, not much more than 300 crank hp can be supported safely.
-Chike
2006 Steel Gray WRX TR (sold)
Old 12-08-2005, 01:42 PM
Just some dude.
Tom and I have both run 9 lbs of boost on the factory injectors. 9 lbs is way more than 300 hp.
-Chike
Old 12-08-2005, 01:56 PM
Chiketkd's Avatar
I don't want to send this turbo piston thread too far off topic, but while Tom (Svxfiles) runs 9lbs of boost, the bsfc on a s/c isn't as high as a turbo. Also, ~300hp at 60psi of fuel pressure is assuming an IDC of ~80%. If your stage 2v5 chip allows for higher IDC's (95-100%%), then yes, someone could probably make around 330-340 crank hp depending on the bsfc with the system their using.
-Chike
P.S. I never realized you're on the stock injectors LAN??? I thought the prototype used the nismos?
Just some dude.
The z32 maf meter will read more like 550hp of air. The fuel injectors are the limiting factor but someone, I think bill or tom has tested them at higher fuel pressures and found that they perform well on up through 60 something psi. This thread is about pistons though....let's not hijack it.
People are finally going to cc the heads of both the ej22 and the svx; that's definitely someting we should keep on track on. It's about time. This year is looking great for the svx; people are actually doing stuff instead of debating it.
Old 12-08-2005, 01:46 PM
Chiketkd's Avatar
It was Bill (SVXRide) who got his fuel injectors blueprinted.
I agree with you 100%. Stuff is actually getting done this year.
Keep up the great work Mike!
-Chike
Old 12-08-2005, 01:54 PM
I think a 6mt and a 300hp figure is more than enough. We still want to drive a reliable engine (lasting) with an acceptable fuel consumption. For most of us those cars are for daily usage.
We shouldn't forget these factors.
Old 12-08-2005, 07:19 PM
immortal_suby's Avatar
Thread Killah
split and moved some posts to keep the piston thread on track and keep this good discussion going.
Locker Link
2015 BRZ Limited 6MT
Old 12-08-2005, 08:17 PM
Chiketkd's Avatar
Good call Matt!
-Chike
Old 12-08-2005, 08:23 PM
Thread Killah
So-
Got my maf from Walter today.
Will be ordering the stage 2 tomorrow.
intake/exhaust setup:
custom butcher exhaust
K&N filtercharger (need to clean it)
Intake silencer removed
Will bumping up the fuel pressure at this point be worth anything on my setup or a waste of time for now.
Locker Link
Old 12-08-2005, 09:02 PM
Chiketkd's Avatar
So-
Matt,
I don't think you need to adjust the fuel pressure, as the Stage 2v5 chip will richen the afr similar to the stage 1v4 (or is it v5). With your mods and the Z32 MAF, your afr will probably remain nice and rich in the upper rpms.
If you ever add a mod such as performance camshafts, then bumping up your fuel pressure will be needed.
-Chike
Old 12-09-2005, 07:07 PM
mbtoloczko's Avatar
sans SVX
Matt,
-Chike
Chike, that's not necessarily correct. If the MAF is not near its limit, and the fuel injectors are not near their output limit, then further performance mods will not necessarily require richening the afr. NA motors generally work best at around 12.5-13.5:1. OTOH, certain mods, such as a turbo, work better when at a richer afr, and in these instances, its reasonable to presume that richening the afr will be helpful.
Mychailo
Visit my locker
