Go Back   The Subaru SVX World Network > SVX Main Forums > Product and Service Reviews > Service Shop Reviews
Old 11-23-2005, 05:26 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up NY/NJ/DE/Eastern PA area mechanic
Our SVX Network member TomsSVX is a college student and an excellent SVX mechanic! He lives in Beach Haven, NJ, charges a rate of $40/hr and offers flat rates on some jobs (e.g. 5 spd swaps). Great guy who's work is even better!
I've used him to replace my timing belt and my front engine seals, as well as replace my front transmission diff and install performance camshafts!
To get in touch with Tom send him a private message.
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-23-2005, 10:16 PM
n00b on demand's Avatar
I can vouche for Tom's great work too. He has helped me out with my car alot of times. Anddddd I might be needing you again with this current problem I have .
Old 12-02-2005, 08:55 AM
Cool... didn't even know this thread was in existance... Anyway I do have some jobs already scheduled so please take note of them before asking about work
1/3/06 4.44 swap for te1221
1/8/06 5mt swap for shotgunslade
Thnx for listing this and thnx for the feedback guys.... Tom... I will see you on Saturday
*edit: PowerOnDemand's car is complete and running fine
Old 12-14-2005, 03:56 PM
Just a bump and edit to the schedual
Old 01-18-2006, 07:40 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Tom definitely is very honest and knowledgeable with what he's doing.
My tranny swap is delayed again because Tom found remnants of bearing shavings at the bottom of the transmission pan large enough to have a concern. Instead of just throwing it in he advised me that we probably should hold off on it until I switched the transmissions with another one (it was still under warranty since it was less than a month old).
Luckily he called me before I came to bring any random stuff I had (my wheel bearings, hub tamer, Mychailo springs, all the struts and suspension goodies) to work on in case there was time left over.
Since we didn't get to do the transmission swap, we lowered my car and he installed one of the two wheel bearings i needed installed.
Ironically after installing my new rear suspension components the car is actually higher than it originally was due to a saggy suspension.
Great work Tom I have the new tranny so we will try again ...
Stage 2v2 here we come (eventually haha)
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-21-2006, 03:34 PM
shotgunslade's Avatar
Took Delivery of Tomstock Stage 3 v 2
Just took delivery of my new Tomstock Stage 3 v 2 SVX. Tom worked with me to identify components required, pointed out sources, and then did the install. Project included Group N motor mounts, adjustable fpr, Waldbro fuel pump, Delta cams, and WRX 5MT. Work was completed in a week for a very reasonable fee. Along the way, Tom identified a hairline crack in my radiator, then sourced and installed a new one, without missing a step. He even arranged to sell my discarded 4EAT, taking some of the sting out of the project. Work was very professionally done. Great service. If you want a 5MT and dont have either the personal or tool resources to take on the task, this is the way to go.
By the way, its a f**king beast.
Old 01-21-2006, 09:28 PM
I hope you like it as much as I do. Let me know if you wanna stop in and have me adjust your rear konis. It is a pretty simple task and you do not need to take it out of the car.
Old 01-24-2006, 12:40 PM
Ok now that I have most of my stuff settled and my final porject planned for this saturday, I can get back to normal. I figured I would throw some info out there for anyone interested.
Auto trans replacement $400 plus parts(1day)
-Replacement of stock transmission with one of the same gear ratio.
-Replacement of transmission pan gasket and internal filter.
-Refill of transmission and front differential with fluids of your choice
Auto Trans upgrade- $500 plus parts(1day)
-Replacement of auto trans with one of a different gear ratio (4.11/4.44)
-Rear differential swap(swapping the LSD carrier from SVX diff to matching gear ratio)
5/6 speed swap $2000-$2100*-$2300** plus parts(1 week)
-Replacement of auto for 5/6 speed manual transmission
-Custom built Cradle style Crossmember
-Shift linkage extension
-Pedal box retro-fit
-Wiring to use reverse lights and neutral safety switch on clutch pedal.
* this is for transmissions besides that of the WRX that need to have the rear differential gear ratio changed.
** this is for the Sti 6 speed transmission in which the owner would like to convert to the R180 rear differential and axles.
I also do most any maintenance of SVXes. This is $40 per hour. Things like timing belt/cam seals/oil pump seals/ water pump/thermostat replacement can all be consolodated into one job. I can also replace your wheels bearings that are screaming at you
If you would like to know more or contact me about your car, feel free to pm me anytime and I will respond as soon as possible
Old 01-29-2006, 07:59 PM
AvPPoW AvPPoW is offline
Another voucher for a great mechanic who works his ass off to please his clients. After seeing Tim's car this weekend I am once again impressed by the quality work and quick turnaround. I've watched him come through time and time again and he's always sure to get the job done. Great work Tom, keep it up!
Old 01-29-2006, 08:04 PM
Couldnt have said it better myself. Tom will come through for anyone in their time of need....he has definitley helped me out quite a bit..especially by letting his dog not kill me.
Old 01-29-2006, 08:20 PM
Thnx guys. Hey Tom congrats on the sale. Just let me know when u want to come down for the reseal. Also let me know when you want me to build you a new one BTW send me a PM i have got some good info for ya
Old 01-29-2006, 09:37 PM
Sale isn't definite yet so im not getting my hopes up or anything. You know what happened last time when i was supposed to swap cars with that guy with the RS and then he pulled out to get an audi or whatever . But yeah whats this good info? Ill PM you now.
Old 01-29-2006, 09:41 PM
by the way i have this coming saturday off so i could swing by in the morning for the reseal....i also have thursdays off as well...just thought i would throw that in considering that you probably have school and all.
Old 01-29-2006, 10:37 PM
This upcomming week is no good. The following should work. Take off not this upcomming Sat but the next.
Old 01-29-2006, 10:43 PM
Tim's Avatar
Tim Tim is offline
Oh man that happened to me too! I thought I was going to get eaten!
And yes the professionalism expressed by Tom is second to none. Everytime he took a break he took the time to call me and let me know of the progress.
He also let me know of things I should take care of in the future and pointed out that my transmission mount was broken, which was the reason for my thudding into reverse.
I really enjoy driving my car now that pretty much all the problems are taken care of with the exception of my lower rear strut seating, which I will replace. I honestly hate taking my car to people to get worked on but currently is one of like 2 other people that I trust touching my car.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
