Old 10-27-2005, 05:00 PM
RedHotSVX RedHotSVX is offline
gettin there....
Send a message via AIM to RedHotSVX Send a message via MSN to RedHotSVX Send a message via Yahoo to RedHotSVX
Factory Trans Filter(external)..
I was reading some other threads about the filter that was installed under a dealer campaign under the battery.There isn't one on mine,and I know the so called trans issues were I guess resolved by 97,is this why?
Secondly is the line on the drivers side or pass side of the radiator the inlet from the trans,I am putting in a temp gauge and I want to put in on the "hotter" line with the filter kit I am going to install.
Thanx All!!!!!
Mike....
8/96......Vin 100109
1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!!
Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines.
1997 SUS Legacy,finally got the engine in after a year!!
www.myspace.com/devilhornz
Old 10-27-2005, 05:30 PM
ShiuludeSVX's Avatar
Thanx All!!!!!
http://www.subaru-svx.net/forum/show...=tranny+filter
Above thread covers your question, by your description.
Old 10-27-2005, 05:40 PM
The external filter was part of the solution to keep the fine particles from clogging the screen that was built into the ATF cooler in the early radiators.
Once the radiator ATF cooler was redesigned (no mesh screen to clog) there was no need for it. Here is the link to the TSB:
http://members.tripod.com/quick_svx/.../42748095.html
The "hotter" side of the ATF (out of the tranny) goes into the driver's side of the radiator.
Check here for diagrams that best suit your needs:
http://www.subaru-svx.net/photos/user.php?How-To|14287
Old 10-28-2005, 05:57 AM
gettin there....
Thank you much.....everything I needed to know!!
Mike....
