Old 10-23-2005, 07:58 PM
sxewhodey's Avatar
sxewhodey sxewhodey is offline
The beast is out!
Well Todd came out for some parts and I was stuck with a motor mount thread that got stripped out. He wanted the radiator core support so that required the whole front to be removed He cut with the sawzall and angle grinder and we got it loose. Then the front was gone and it made it a hell of a lot easier for me to get to the one last bolt holding things in. Busted it loose and pulled it out the hallowed out front end. I did get a bend in the pan though from something (not sure if it were pulling or rubbing something) so tranny fluid is leaking now but that gives garage floors character . So thanks to Todd for his help and motivation on how to eliminate a tow truck trip to the junkyard, hahaha.
and another pic...Hey, Wheres my Nose?
Old 10-23-2005, 08:26 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Originally Posted by sxewhodey
Beautiful pic!
2006 Steel Gray WRX TR (sold)
Old 10-23-2005, 11:59 PM
THAWA
That transmission looks new/rebuilt.
Old 10-24-2005, 02:53 AM
Why are you doing this???
Old 10-24-2005, 05:51 AM
sxewhodey's Avatar
The tranny has only 5k miles on it
It only has 5000 pls miles on the remanufacture, thats why I got the car. Its practically new. The replacement was over 4000 to the previous owner so I got on it and Im stripping the car for parts.
Old 10-24-2005, 05:56 AM
wawazat??'s Avatar
Yeah, I'm still around
Hiya Mike! Glad she finally is loose Got home later afternoon and got motivated too. Got the oil changed in the truck as it was good and hot after the long haul, and then finished a garage wiring project that I've been working on so that I can get back on the SVX projects.
Danny-this car was totalled by the insurance company (rear end collision) and I needed parts for my '94 Laguna Blue which was in a front end collision.
Todd
Down to none
Old 10-24-2005, 10:33 AM
Todd
Oh...
Old 10-24-2005, 02:20 PM
rufus's Avatar
rufus rufus is offline
I look like Gordon
Just looking at your picture, I'd bet you just bent the dipstick tube and no longer have a seal where it meets the tranny. There's only one bolt there and the metal tab on the tube is pretty weak.
It is very easy to do when removing the tranny, trust me.
First the smiles, then the lies. Last comes gunfire.
Old 10-25-2005, 12:46 PM
sxewhodey's Avatar
Rufus, Im pretty sure youre right
That was the only place where it was leaking from. I originally thought it might be that but I wasnt sure how weak they were. How easy is it to fix this problem? A screw loose or new gasket maybe? Thanks in advance for reply.
Old 10-25-2005, 08:53 PM
rufus's Avatar
I look like Gordon
Take the tube off (there is the bolt where it meets the tranny, then another on the stand-off a little farther up the tube if I remember correctly). Gently bend the tab down a little (away from the handle end of the tube) with a pair of pliers. Take care not to break it, but I would bend it just a little past 90°. This will put some extra pressure on it when you tighten the bolt back down. It certainly would not hurt to replace the o-ring at the bottom of the tube, either, but I'm guessing the o-ring is not the problem. Reinstall and roll the tranny towards the tube side a little to get some fluid up against the seal and check for leaks.
I hope this works, it has for me in the past.
Another note on your earlier post... If the pan is bent, there is a chance that the bottom of the pan will actually rest against the inlet of the tranny fluid filter and effectively block the flow of fluid. I have been through this one as well. Check carefully before you re-use the current pan or you may have some heart-stopping moments when you fire everything up and the car doesn't want to move. If you drop the pan, you may even see a mark in the paint (on the inside) that matches the inlet port on the filter. These pans have roughly the bending resistance of an aluminum beer can
Mmmmmm beer.
If it is bowed in far enough to cause this problem, either beat it out with a rubber mallet or get a new one. I think they are pretty cheap.
Good luck, and keep us posted.
Oh, one more thing. If you remove the pan, torque the bolts very carefully when you reinstall it. They snap like matchsticks.
Old 11-08-2005, 11:58 AM
mudfoot76 mudfoot76 is offline
Send a message via ICQ to mudfoot76
holy crap
Yeah, it was barely one year old when an old bastard smashed into me
$4k for that new tranny down the drain, and sxewhodey buys a fantastic parts car for f'in cheap. I regularly have to drive past the offices where that jerk's insurance rep resides, and I take the opportunity to give them the finger each and every time...but I digress.
Unless you're planning on junking that transmission, I'd suggest you be careful. It was practically brand new when I sold the car to you. You could easily make back the $$ you paid me just be selling that transmission. [Damn, I wish I had the facilities to part that car out....]
Geoff
1973 Porsche 914/2.0
2005 Mini Cooper S
Sold: 1994 LS-L Laguna Blue [to sxewhodey]
