Diff or cv joint?
OK, finally got my 96 on the road with new level 10 stage 2 kit and reworked valve body. Small problem, when turning left at low speeds I am feeling some binding like symptoms and clunking. When I had the front end jacked up and in park I could still turn the front wheels by hand. Anybody have any ideas before I investigate further.
1999 Audi A8. No more SVX's for now. |
For the binding, I would try fitting the FWD fuse, to see if the binding goes away. If the Transfer clutch has been set up a bit tight, it may take a bit of bedding in. I would let Level 10 know what is happening, they may have more to say. Harvey. ![]()
Thanks for the response Harvey. I though the parking pin, if there is such a thing might be broken. I am glad that is not the case. I only purchased the kit from Level 10 and send my valve body to them to be reworked but had a local transmission shop do the install. Are the transfer clutches usually replaced when doing a transmission job? It's the clunking that has me more worried than the binding. My 92 has slight binding issues also, but no clunking.
I came across a site "dba.com.au" (disk brakes australia) which has some interesting rotors for the svx. Would you have any experience with these by chance.
So the clunking is going to be either the front differential or the axles. My bet is still on the axles as the noise occurs only while turning.
I sure hope so. Axles much cheaper. Do want my used airbag control module. Maybe they can be reset?? Was going to throw it out.
I think the airbag control module is a 1 shot deal as with everything involving airbags
http://cgi.ebay.com/ebaymotors/Airba...QQcmdZViewItem
Though I would send this link to you for what it's worth. Could be risky, but who knows?
The clunking could be the CVjoints. Raise the car on a lift, run the wheels slowly, and turn the steering wheel from lock to lock, to see if the cluncking happens. DBA make some of the best rotors that you can get. Being Australian, they aren't just a copy of some other rotor, they develope them in road and rally racing. Very inventive, there Kangaroo paw venting is unique. Harvey. ![]()
Re: Diff or cv joint?
I am reviving this thread because I find myself in a very similar situation.
1992 SVX with just over 200,000 Kilometers Has been throwing TCU error code 24 (Duty Solenoid C) for a while. Has likewise been locking the wheels up in tight/slow turns for a while. Recently developed bad clicking and then crunching noise in front end during tight turns. First thought was CV joints. That is what it sounds and feels like to me. But, got under the car and all 4 boots on front axles are in great condition. Was puzzled. Tried putting in FWD fuse. Does not work and does not illuminate FWD light. Replaced TCU. Still no FWD light. Still gives error code 24. Hypothesis 1) Long term non-function of Duty Solenoid C has caused CV joints to wear out prematurely despite the fact that boots are not damaged Hypothesis 2) I have developed "rare" differential problem, due to long term driving with code 24 - Duty Solenoid C Any other thoughts out there? |
