ok so i got a stock pulley from svxfiles and when i went to put it on i found out why mine was wobbling. the little slot the crank key slips into on the pulley has been gouged out to 3x it's original size and the key on the crankshaft is cocked sideways
![]() Last edited by Budfreak; 10-11-2005 at 01:18 PM. |
If you can take some pics as it'll help people trouble shoot your issue better...
![]() -Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 09-27-2005 at 11:03 AM. |
That's a difficult problem to fix. I really hope that all goes well for you.
I think you may have to use a puller to get the pulley off the crank shaft. There could be problems with this method. The crank shaft could end up getting damaged if the key doesn't straighten out. Was the bolt loose? I think this damage could start if the bolt came loose. Another possibilityis the ac, ps, or alt siezing up and twisting the crank pulley. The belt would have to have been real tight for that to happen. Is the pulley loose on the crank shaft? If it is the shaft may be damaged. ![]()
May your transmission live forever. SuperbVehicleXtraordinary Proud sponsor of a 1992 SVX. ![]() |
i'll probally need a puller for the timing gear but the pulley comes right off. we figure either the bolt came loose at some point in it's life or like was said something froze up but those belts would have had to been plenty tight. but that is what kinda looks like happened though
ok so heres some pics of the chaos. it's kinda hard to see but the key on the crankshaft is bent pretty good and you can see the great big opening in the pulley that should be no bigger than the crank key. this is gonna suck
That looks like one of the many things that happened with the Teg except my bolt was gone before the key was turned to dust replace the key and the pulley and hope that it didn't bugger the end of the crankshaft. also the pulley and key took all the damage on the Teg.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. ![]() 92 SVX LS-L Perly ~186k R.I.P. ![]() 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver Last edited by thundering02; 09-27-2005 at 06:24 PM. Reason: Spelling |
![]() Quote:
Don't have a clue got into the driveway for the battery to die(no alternator with no belt moving it) got uunder the hood the net morning to fing the bolt gone. no evidence it had been there for a while either
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. ![]() 92 SVX LS-L Perly ~186k R.I.P. ![]() 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
I had the same problem and my belts actually let loose. Being close by I went to the dealer just running on the battery.
My ass still hurts from the raping but the guy did a good job. My pulley had the same keyway problem and he told me he had to pretty much make some ghetto key to hold the pulley on there. He also stated to make sure I always have that bolt torqued down to spec and spit me out the numbers. Of course if would help if he supplied me with the subaru tool to hold the dam pulley. Good guy though but oh the dealer sucks - I was pissed when I got the bill. Good luck
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing ![]() 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
ok now i'm screwed. the gear puller just broke the timing teeth off the back of my crank pulley. don't know what to do but sit here and miss work. I"M SCREWED!
Oh crap that's not good. The holes in the T-sprocket need to be tapped for bolts. The puller then pulls on the bolts and not the back of the T-sprocket.
well, there may be a 92 for sale on here soon. the gear is shot and the POS puller screwed up the threads on the crank too. couldn't do it with the bolt in cause it was too long and was hitting the radiator. well, i think i'm screwed and it's over cause i can't afford to fix it. either someone volunteers to fix it or i'm screwed cause i'm not dealing with it much more than this.
Obviously the puller isn't what fouled the threads. Sounds as though it's time to let someone with more skills fix it before you cost yourself more money. It isn't the end of the world and the repair will cost you less than selling cheap. No, the crank doesn't have to be replaced, and as long as the key slot isn't damaged, doesn't have to be removed.
Sorry, I can't make the truth less painful to hear. ![]()
![]() looky what i did ![]() ![]() |
Glad to hear that! Unfortunate that you didn't grind the key down first. Hope the crank slot is in good condition. Make sure the bolt is torqued down so it doesn't happen again.
