Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 09-26-2005, 08:44 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Thumbs up 5 speed progress update
Well I actually went and worked on the 5 speed over the weekend. I managed to get the pedals physically mounted and the brake booster/master cylinder bolted up.
A few notes:
My clutch pedal still had the cable connector even though it was a hydraulic unit. This presented a problem. After mounting the pedals, when I pushed the clutch petal down, the cable mount pushed up into the wire loom. Obviously that would not do. I took the assembly back out and cut off the cable arm and then had no issues.
I have included two images. Image038 shows the cable arm and how high it protrudes when the pedal is pressed and Image039 is after I cut off the arm and smoothed the edges. The images are from my phone since I didn't have a real camera with me.
The next step is to mount the clutch master. The bolts are in place, the hole in the firewall is there. I just need to add about 2 inches to the master's rod to get it to reach the actuating lever. I quick trip to the hardware store and a few minutes with the welder will take care of that.
Other things left to do:
Install Starter
Install Rear diff and rear axles.
Mount rear shifter mount bushing on the body
Have driveshaft lengthened.
Install driveshaft
Install exhaust
Drive!
I'm getting closer
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 09-26-2005, 09:10 AM
mbtoloczko's Avatar
sans SVX
Good to see you back at it. Pretty soon, there is going to be more 5MTs on the network than ATs! :-)
Mychailo
Visit my locker
Old 09-26-2005, 01:52 PM
Great news! So will it be ready for the 15th anniversary meet?
Hehe, at least you won't have to take 2 SVX's to the meet in hopes that at least one will make it!
(j/k)
