Voltage doubler?
Does anyone know where I might be able to find such a beast? I'd found an old fire allarm bell that I want to use as a horn on my truck, but 12 volts is half of what it needs to make serious noise
.Karl. Southwest members, click here to check in!CA,NV,AZ,UT,NM,OR,CO Wanted...your busted SVX! Watch out Earl, I'm comin to getchya ![]() Return of the Pissed Platypus! X2 My dream (other than a pearlie) 1.8 SVXi and a laguna blue spoiler...somewhere ![]() I decided to quit drinking, but I didn't like it so I quit not drinking. |
Wire two batteries together in series.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. ![]() 92 SVX LS-L Perly ~186k R.I.P. ![]() 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
Depends on the amount of current needed for the horn. 24 volts can be made with two batteries in series - but you'd have to get a 2nd battery. But if there's just a little bit of current then you can get away with an IC step up (boost) converter.
Other wise - time for a SMPS (switch mode power supply). Do a ![]()
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing ![]() 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
Ooh! Ooh! I know!
Just run two sets of wires to it. Stepping up DC current is pretty big hassle. I wonder what sort of voltage your bell operates on internally. I've only seen 120 VAC fire bells that ring at 60 cycles. Unless it's got some sort of mechanical crank to whack the bell, there must be some circuitry to turn the 24 VDC into some sort of AC. Many fire alarm and suppression systems are 24 volt, but I've seen 12 volt outputs, 12 volt devices, and 12 volt devices modified to operate on 24 volts. (All were bizarre set ups.) My familiarity with those systems is pretty limited, but I wouldn't be surprised if you took it apart and found something that could easily be rewired. I would imagine that the bell sucks quite a bit of juice, but so do laptop computers, and you can buy power supplies for them that run on 12 volts. |
Thanks all, hmmmmm, don't think I can run to batteries in paralell and in series at the same time :O so I was trying to keep it simple, coming up with a couple ideas, may not be able to do it off the stock truck electrical system, duknow. It does work on 12 volts DC, but it is so quiet that anyone more than 20 feet away would burn to death before they heard the bell...
go and just buy an e-horn and speaker. cheaper.
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
But I want a real fire allarm, a speaker just cant replicate that sound!
