Has anybody cut apart the rear deck?
Our racing hood/deck pins will arrive next week. I'm planning to remove all hinges and latch hardware and would like to cut the inside of the trunk lid apart to lighten it up. Has anybody done this or better yet does anybody have a junk lid they don't mind cutting up. I just want to be sure that the outside will be strong enough to hold its own. I'd imagine muce of the strenth is needed for the opening and closing which we will no longer have as it'll simply lift off.
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
Didn't Mike have a few extras?
I added a few parts to my trunk lid and realised the material is about 4 mm thick but crumble easily
If you still want to open it, I'd not take out all structural parts in the trunk lid but rather go the classic way: leave the hinges and latch and drill lots of holes into the inner parts of the lids. You can even use a circular saw up to 4 - 5" (hope that's the right expression) and take out larger sections. |
I believe Paul (SVXHunter) gutted his trunk lid on the SVreX, might PM him
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
I did it.
You'll be surprised how little you save. You will add almost as much in the hood pins as you remove. The rear deck is plastic. All of it. It is no where near as heavy as it seems. The hinging is sort of a reverse leverage which makes it seem heavier than it is. We ground all the structure off both the front and rear hoods. They are just skins attached by hood pins. They have a high cool factor, but no real significant weight savings. They are pretty weak. The hood is worse than the trunk. Here's a pic at this year's GRM Challenge
'92 LS-not-so-L: the "SVreX"- Saved from a crusher, an SVX racer built by home schooled students for less than $2000 (including purchase price). 13.8 second 1/4 mile. Autocrossing monster!! ![]() '92 LS-L Claret: '01 RS 4:11 5-speed, Exedy organic, lightened flywheel, and Koni/ GC ![]() |
not to hijack the thread, but has anybody tried molding some lexan to replace the windows.. that could save some weight if that is in fact the idea...
BTW.. man SVREX looks cool.. awesome spray job
-Alex 1996 Brilliant Red LSi "Allie" +226k mi. 25,000 lb GVW Trans-Cooler Wet-sanded "cleared" Headlights Charcoal 22% Tint Removed intake resonator '95 Probe GT Wheels '97 grille "New Addition" 1992 Teal LS-L +156k mi. Status... Reconditioning |
Thanks!
I thought someone posted that the windows were actually very light?
