Throttle Body bypass mod - with pics!
While there's already a how-to document about this mod, I personally found that there wasn't enough pics which caused me some confusion when trying to visualize the step-by-step process.
After talking the process over with Svxfiles, I decided to do this great 'free' mod and take step-by-step pics for everyone else: To give yourself adequate room to do this coolant bypass mod, remove the stock air hose that runs between the airbox and throttle bodies. Driver's side coolant hose Passenger's side coolant hose There's a spring clamp on the end each hose. Use a needle nose pliers to open-up the clamp and slide it down the hose away from the end. Place a rag under the hose and pull it off. Some engine coolant will run out, but not very much... This was a t-fitting I used to join the two hoses - this connector was actually incuded with the phenolic spacers I purchased from Outlaw Engineering... The t-fitting simply slides into the hose and then use your pliers to re-position the clamp on the end... All done. All in all it took me ~20 minutes from start to finish. -Chike P.S. It's also a good idea to cover up the openings in the throttle body that the coolant went into and out of - I used some high temp electrical tape, just to keep dust and other debris from getting in.
hmmm i could do that.
Chike
I put it into a PDF file and will put it into the How-To Docs.
Chike
Is it a T fitting or just a connector? Looks like a connector, not a T. Let me know and I can edit it for you.
Nice pics. Have you driven the car yet?
Nice job Chike,
A picture is worth a thousand words. I can do THAT TOO! Quote:
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
anyways... thats a straight through fitting if you will...
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
<Al Bundy> I can't find any of the "L" brackets that they talk about.... Just a bunch of these things shaped like a "7"??? </Bundy>
its called a nipple in the plumbing world or a barbed nipple if you will. Some call them plain old barbs but I like the word nipple too!!
Tom(What a dirty dirty mind I have ) |
i just bought the I fitting at home depot for 1.47. it is 3/8 of an inch fitting like the other thread said? good pics to. i still have yet to install.
Thanks for the tip, I'll take a look at HD.
Chike, wanna submit that to the SVXipedia too?
I myself would not recommend this, because of the possibilty of sh1t happening, and I think Beav would aggree also. Harvey.
Day 2 and I haven't noticed this mod showing any seat of the pants benefits. We'll see, though I may be reversing it if I don't see results within a week or so.
