Old 05-16-2005, 10:31 AM
92AWDSVX
Please HELP!!!
Ok, this morning i was going somewhere, and i went to start my car and NOTHING, no lights were left on, but it tried for like 2 seconds, and now the car just clicks, and nothing happens... Its been havin a little trouble, like it seems like it might be a lil hard to start for the past couple days, but i didnt think anything of it, it wasnt bad, it just didnt fire right up... but this morning it tried for like 2 seconds, and now it just clicks when i try and start it!? PLEASE HELP ME! WHAT U THINK IT COULD BE? Starter? Alternator? or what?
Old 05-16-2005, 10:52 AM
dcarrb dcarrb is offline
Dead battery.
Old 05-16-2005, 10:54 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Originally Posted by dcarrb
Dead battery.
I concur. Remove the battery (or, get a jumpstart -- if it starts, it's another sign of a dead battery), go to Autozone or Advance Auto for their FREE charging system test.
Randy Johnson
Mike Davis -- at Reading VI
Old 05-16-2005, 01:29 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I had a similar problem. It could be the battery or the contacts or it could be the ignition switch. I had my battery checked, it needed to be replaced. I still have the problem but only once in awhile. I believe my problem is the ignition switch. I'm going to try the relay bypass fix first. ( you can find many threads on this subject) Good luck.
Old 05-16-2005, 04:15 PM
Could be the battery, alternator, or starter. How bright are the headlights when you turn the key on? If they're bright it's the starter/ignition.
Check the voltage when the car is running. It should be in the 14V range. If it's lower it's the alternator.
If it's none of these then it's likely the battery.
Old 05-16-2005, 05:34 PM
SubaSteevo's Avatar
No longer blue member
If it's not the battery, you might be able to fix it by installing a relay before the starter. There was a recent thread about it somewhere.
-Steve
01' MSM Lexus IS300
Old 05-16-2005, 09:07 PM
92AWDSVX
Its the starter i think, cuz when i hit the starter it tried to kick over and was but then the batter ran out of juice...
And my cousin had the car b4 me and he had the same problem and when he hit it it ran fine, i need a new starter, where can i get one for CHEAP???
Old 05-16-2005, 09:40 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Did you try to jumpstart it yet? Did you go to autozone for the free check yet? How can you be so sure it is the starter?
Sounds like a dead battery.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 05-16-2005, 09:57 PM
92AWDSVX
Yes i tried to jumpstart it, and i cant get to autozone cuz it wont start, and i even tried charging the battery, NOTHING, so i hit it a couple times, and it started to kick it over but then froze again...
Old 05-16-2005, 10:30 PM
SubaSteevo's Avatar
Try the starter relay mod before you buy a new starter
-Steve
01' MSM Lexus IS300
Old 05-16-2005, 10:47 PM
92AWDSVX
haHa how the hell u do that? haha
Old 05-17-2005, 10:51 AM
Best way to find out is use the search feature and search for "starter relay"
