Keys stuck in the ignition what should i do?
A couple of days ago i used my spare key to start my SVX, it worked fine untill i tired to take it out and it wouldent come out, it wouldent go past the ACC mode. The weird thing is that if i turn the key to the on postion it easiley comes out, and can be put back in, but if i try to put the "good" key in it won't accept it. Any idea on what i should do?
I think that's a new one to me. Are the grooves different between the keys? Is one key more noticably worn than the other? Is the ignition loose at all?
wiggle it till it works.
I once used a 94 key on my 92 once and took a while to get it to come out.
Lwin M. Maung (Member # 147) Current SVX: NONE Previous SVXes: 1994 LE Barcelona Red 107k 1992 LS-L Pearl White 143k 1994 LSi Bordeaux Pearl 220k 1992 LS-L Ebony Pearl 184k 1992 LS-L Liquid Silver 145k 1992 LS-L Liquid Silver 102k 1992 LS-L Ebony Pearl 123k Other current cars:2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
Could the "park" lock solinooid be not disengaging?,
Keeping it from going to the "off" position? Keep us posted on what it takes to fix it.
Yes the keys are noticabley difrent, there are a couple of ridges that are missing on the "bad" key. Iam going to check to the lock solinoid, or if the wires are hooked up. |
My users manual for my car indicates a switch under a panel on the steering wheel to release the key. I suggest looking it up in yours. It sounds like the park lock. My key does the same thing if I'm not in park.
I had the same problem with a 91 legacy when the seat belt fuse blew out.
Green 1994 SVX LSi - Totaled by a plow. RIP Bordeaux Pearl 1994 SVX LSi - 182k |
http://www.subaru-svx.net/forum/atta...&postid=162786 will this help?
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
In what direction and way should I push it to work. Ive tried pushing it to the side and over various ways but it did nothing. Thanks alot for the repleys.
I Had Some Keys Cut At Walmart. They Looked Fine.i Didn't Notice Any Problem Until The Key Would Not Come Back Out.
Walmart Had Cut The Correct Key Blank Without Getting The Key All The Way Into The Key Cutter. They Paid For A Locksmith To Remove Their Old Key And Recut My Keys Properly. I HAVE A 2002 LANDROVER DISCOVERY AND A 95 AEROSTAR THE KEY GETS STUCK EVEN ON FLAT GROUND AND TURNING THE STEERING WHEEL UNLOCKS IT . IT CAN TAKE LONG ENOUGH TO MAKE ME LATE FOR WORK. USING THE EMERGENCY BRAKE KEEPS IT FROM LOCKING. WILL SPRAYING SOME KIND OF LUBE IN THE IGNITION CYLINDER PREVENT THE LOCK UP? Sheesh I Can Just Barely Read This Little Print Even In Capitals.
DWAYN |
I know it is more expensive than at WalMart, but I go to the dealer and get mine cut there. They don't go off of your key. They go by the key number so it will be perfect every time (I hope).
. Earl .... ... .... ><SVX(*> Subaru Ambassador [COLOR=silver]1992 Tri Color L[/COLOR] ~45K (06/91) #2430 1992 Dark Teal LS-L ~184K (05/91) #0739 1992 Claret LS-L ~196K (05/91) #0831 1992 Pearl LS-L ~103K (06/91) #1680 1992 Pearl LS-L ~151K (06/91) #2229 1992 Dark Teal LS ~150K (07/91) #3098 (parts car) 1992 White LS-L ~139K (08/92) #6913 1993 25th AE ~98K (02/93) #164 1993 25th AE ~58K (02/93) #176 1993 25th AE ~107K (02/93) #215 1993 25th AE ~162K (02/93) #223 1994 Laguna Blue Pearl LSi ~124K (1/94) #2408 1994 Laguna Blue Pearl LSi ~144K (10/93) #1484 1994 Laguna Blue Pearl LSi ~68K (10/93) #1525 1994 Barcelona Red LSi ~46K (02/94) #2624 1994 Pearl LSi ~41K (12/93) #1961 1995 Bordeaux Pearl LSi ~70K (02/95) #855 1996 Polo Green LSi ~95K (03/96) #872 1997 Bordeaux Pearl LSi ~55K (08/96) #097 2003 Brilliant Red LS1 Convertible ~29K (04/03) #8951 1999 Magnetic Red LS1 Coupe ~33K (04/99) #6420 My Email | Old Locker | New Locker | Picture of 15 of the 19 |
Robert Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me. Update: 09 January, and still not in jail! Wassup?? 1992 Teal LS-L - 160k (Now new and improved with perfect paint!) |
I had a difficult time trying to get someone to cut my OEM key blanks. Most people only cut brass keys. The OEM's are much harder than brass.
Is it turning all the back?? If not, there is a small lever under the dash that is sunk into the plastic cover. Just push the lever over and it should allow you to turn the key all the way back and pull it out. I had my 94lsi 5 speed get stuck once and it took all day to find out what the heck was happening
Tom |
