Old 03-21-2005, 06:34 AM
IggDawg's Avatar
IggDawg IggDawg is offline
0h n0es!
Send a message via ICQ to IggDawg Send a message via AIM to IggDawg
Odd climate control problem
Hey all
I have a weird problem with my climate control. It doesn't work. cool huh? The digital display won't read out anything, and pressing the buttons does nothing. The odd thing is that the clock also doesn;t show up, and the fuse that is blowing is the power mirror/cigarette fuse... the fuses that actually deal with climate control are fine.
When I picked up the car a couple days ago everything worked fine. now it blows the fuse the moment I try to replace it. I haven;t had the car long enough to tamper with it much. any ideas?
IggDawg is cool
-IggDawg
1992 Teal SVX LS-L 160k miles
4.11:1 final drive, K&B dropsprings, ART front rotors, stainless steel brake, aluminum underdrive crank pulley, Kuhmo Ecsta Supra 712's, K&N drop-in filter. Previously owned by Alacrity024. FOR SALE
1994 SVX LSi, Barcelona Red #1659, build date 11/93, 117k miles, RIP
ECUtune stage 1, bead crush, smallcar shift kit, TB bypass, SS brake lines, silencer removed, alternator and grounding wires, Mobil1 @ 117k
Old 03-21-2005, 02:28 PM
deruvian
Is the cigarette lighter module actually in the 12v power port? Occasionally when I put the actual cigarette lighter into the 12v port, a fuse blows that turns off pretty much anything that has to do with the front-center of the car. Clock, climate control, cig lighter, etc.
Remove the cig lighter module and see what happens.
You may also want to try disconnecting the 12v port all together, or check to see if the fusible link on the back of the port is blown/barely connecting. If it is, simply replace it with some copper wire or something.
Old 03-22-2005, 12:11 PM
IggDawg's Avatar
0h n0es!
I played with the cig lighter for a while to no availl. then I tried some searching and found this thread
http://www.subaru-svx.net/forum/showthread.php?p=294793
which completely solved the problem. stupid vanity mirror.
IggDawg is cool
-IggDawg
Old 03-22-2005, 04:53 PM
immortal_suby's Avatar
Thread Killah
I almost replied with that trick last night but figured it was too far fetched for what you described. Glad you got it figured out.
Locker Link
2015 BRZ Limited 6MT
