Go Back   The Subaru SVX World Network > SVX Main Forums > Wanted or For Sale
Old 03-17-2005, 11:26 PM
gl1674 gl1674 is offline
Available: Free Engine Parts
Available: engine block and heads (heads are removed from the block), free to good home, you pick up (will not deliver). The block is stripped of accessories - no sensors, sprockets, just the block case with pistons and crankshaft. Heads come without camshafts, lifters negotiable.
Condition, the good:
- Passed emissions just before disassembly, reasonable leak down tests (15-25%)
- Smooth idle, no lifter noise.
- regular 3k oil changes at least for the last 72k
Condition, the bad:
- 172k
- gunked up a lot despite regular 3k oil changes and periodic flushes
Condition, the ugly:
- Slow leak of water into oil (has been present for many years). Assume a crack in a head or block, not a head gasket.
- Small Leak of exhaust gases into water (the reason for engine removal). Also assume a crack, no traces of failure in the head gasket were visible.
- Half oil pressure at idle, full pressure at 2000 rpm. May be the original oil pump is worn, may be bearings.
You pick up in East Bay. If nobody picks up during the next week, I'll crack the block case open - I still want to see where it leaks - and invest $13 for the visit to the local dump station.
It's probably close to 200 pounds of aluminum, must be worth something to somebody
Old 03-18-2005, 09:29 AM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
send a PM to SVXtacy, I know he's looking for a block.
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
Old 03-25-2005, 03:16 PM
NeedForSpeed NeedForSpeed is offline
I need them!
Sent you a PM last night. Let me know when and where, and I'll be right over to pick it up.
Thanks,
Ron
Condition, the bad:
- 172k
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 03-25-2005, 11:19 PM
NapaBavarian's Avatar
Good morning!
Looks like I'm too late But in Napa if the first 2 don't grab it.
.Karl.
Old 03-26-2005, 01:47 PM
Roo Roo is offline
Send a message via AIM to Roo Send a message via Yahoo to Roo
intake
Do you have an extra intake manifold? Maybe? The previous owner thought that spray-painting the entire engine bay with black Krylon was the way to go, and I'd really like to get a shiny silver one...
'92 SVX LS-L
Project Car for Open Road Racing
Old 03-26-2005, 10:45 PM
Roo, I do have the manifold and since you are the first to ask, you can have it.
Napa, sorry you are next after NeedForSpeed.
Old 03-27-2005, 01:53 AM
Roo- Can I have your old painted manifold after you swap? I can clean it up no problem.
Napa- I can really use the parts and have made arrangements to get the parts.
gl1674- Thanks for your generousity for Roo and myself.
Old 03-29-2005, 06:54 AM
Roo Roo is offline
NeedForSpeed - I'll hold it for you here in Sebastopol, or have it in the trunk in San Rafael (I work for Marin Mazda Subaru).
gl1674 - I want to thank you for your generousity, and will get you pricing for the part you requested. It's never a bother to help a brother...
'92 SVX LS-L
Old 03-29-2005, 09:31 AM
Thanks Roo,
Let me know once you get it swapped.
Old 03-29-2005, 10:53 AM
Good morning!
Sounds good Roo, I'll need some parts in the next few months, but I don't know exactly what yet, I'll yell when the time comes, I think it is mostly outside of the block/heads.
.Karl.
