New Turbo Ideas!
I was watching "Two Guys Garage" and they featured a new turbo set-up that locates the turbine/compressor in the BACK of the car. They say that with the increased distance from the engine to the turbo, everthing runs cooler; turbine is cooler thus transfers less heat to the intake air, and you don't cook the oil either. They also claim there is no additional turbo-lag since it is a positive displacement(?) system since the whole thing is pressurized.
There is more info on these sites. Check them out! http://www.twoguysgarage.com/thisweek/ http://www.ststurbo.com/
cbx-man '92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter '92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft '80 Honda CBX in-line 24 valve 6 cylinder |
Actually if you search you will find at least 2 other threads about this style turbo.
There is gonna be some turbo lag. Not only is there going to be lag on the compressor side, but there will also be lag on the turbine side.
yeah i started one of those threads.
did they dyno it before and after?!
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing ![]() 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
While this method might work with smaller turbos and larger engines, the efficiency losses make this seriously infeasable for smaller engines and any kind of decently sized turbo.
The colder exhaust due to the distance from the engine and the huge length of boost piping required will murder turbo efficiency and create a ton of lag over a properly configured turbocharger setup. |
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
