Old 10-27-2004, 08:03 PM
tracedog67
rotating tires
Ok,
Since we have stock directional wheels what is the best way to rotate the tires on our SVXs?
Tdog
Old 10-27-2004, 08:16 PM
lee lee is offline
I find it to be while driving in "D", I can't back up too good.
slightly more serious, stay on the same side, front to back, back to front. Just remember to adjust tire pressures since they aren't at the same value front vice back.
Old 10-27-2004, 08:25 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Thumbs up
Everything Lee said is correct.
I did this on my car a month ago. When adjusting the tire pressures, you may want to try 40 psi front and 36 rear. Several members have found that their tires wear more evenly at this inflation as compared to the factory suggested pressures.
-Chike
2006 Steel Gray WRX TR (sold)
Old 10-27-2004, 08:31 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
-Chike
Tire pressures depend on the tires, not only the car. General rule is a bit less in the back though. I run 44 front and 40 in the rear.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 10-27-2004, 09:40 PM
THAWA
I was under the impression that tire pressure was based entirely on the car, and what you're doing with it.
Old 10-27-2004, 10:04 PM
BoondockSVX
Do it about every 5k if you can.
Old 10-27-2004, 11:16 PM
Alycone's Avatar
Alycone Alycone is offline
Sue isn't really striped
Huh, guess I better get around to rotating em.
