Made a POWER MODE switch
yes and it works...
Relay, momentary switch and two resistors on the TPS wire going to the TCU. Optimal resistors would be a 400 ohm and a 1K ohm. If you can't find the exact one you can always series/parallel other resistors. the goal is to make about 4V from 12-14V. Enjoy: I've played with it and it's cool .......really does raise the shift points even under normal acceleration. Just try not to HOLD DOWN the button .....that's less desirable.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
at what rpm is the power light supposed to go on....ive almost hit redline and no sight of the power light. it only blinks like twice when i start the engine..thats all i see of it.
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
the power light is not rpm based
it is activated by the ... speed in which the accelerator is pushed slam down on the pedal quickoly and it goes on floor it by slowly putting it to the floor and it won't go on you can even just tap the pedal very quickly from the top liek 1/4" down and let off and it will go on
SV What? |
I am so going to make one of these when I get my SVX. Looks very fun.
Green 1994 SVX LSi - Totaled by a plow. RIP Bordeaux Pearl 1994 SVX LSi - 182k |
Re: Made a POWER MODE switch
That's great! Sounds like it could be a lot of fun. A word of caution to others who might try this: the wires going to the ECU changed colors AND positions over the years. Always check with a service manual (or someone who has one) before you cut wires! Dave |
yes good point. To check if you have the right wire use a multimeter/voltmeter set to DC voltage. Put one lead on the suspected wire and the other lead to ground. With the ignition on you should be reading about 0.3V, then press the throttle and you should see it go up, at WOT it should read 4-4.5 V.
All you're doing here is "blipping" the throttle to the WOT position. So hit the button fast and the TCU will think you just floored the throttle real fast and want power mode. Once it's engaged, you have to drive the SVX somewhat hard to keep it on.
i have the Lsi 1996 i've never seen the power light go on when i start the car or when i pushed it to the max real quick. could this be bad not having the power light not going on? also do the 96+ not have a power light that works?
from what i understand OBD-II SVX's don't have power lights ...
Just wanted to confirm that... OBD-II cars (96 and 97 only) don't have the POWER light. I can't say if it even has the POWER mode... doesn't feel like it as I've never felt my 96 take off like my 95 could. Maybe another attempt by Subaru to make the trannies last longer?
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
'95 Subaru SVX L-AWD 88K miles. |
Once in power mode, if you keep driving hard it won't disengage. Let of the gas for a couple seconds and it'll shut off. This mod doesn't permantely engage power mode because it doesn't alter anything. It just blips the throttle electronically so the TCU thinks you floored it, but the engine revs do not increase because the butterfly isn't physically moving.
If you hold down the button the TCU thinks you're flooring the car (WOT). So, it'll downshift to the lowest possible gear, meanwhile the butterfly is barely opened. Because of this the engine is putting out a lot of effort, and the trans will suddenly upshift into it's normal gear. There's no point to hold the button down anyway. This is just for a change in shift points ...that's all, you won't feel like an instant power boost simply by hitting the button because you're not feeding any more air into the engine. It's still fun to have it shift at 3k under mild acceleration rather than 2k. Today I hit the switch under maybe half throttle ...power light kicked on and it didn't shift til about 6.5k ...cool thing is that it just creaped up to 6.5k nice and slowly
okay okay ....the more I play with this the cooler it gets. It'll do one of two things under normal acceleration .............1) Downshift if its in a real high gear ........or 2) hold the gear you're in rather than shifting .........oh it's cool .........so cool because you don't feel any jerking of the car - it's like I finally have a lot more control over how I want the 4EAT to shift. I was goin real fast on just regular roads and not realizing it simply because the transmission is holding the gears longer .....oh i love it - just gotta be careful.
Anyone scared to do this? If so I can "mass produce" them and ship em out for like $20 (that includes shipping).
If you wan't PERMANENT power mode, you have to connect a 400ohm resistor and a switch in parallell with the 4EAT temp sensor
resistor and switch. (A)o----XXXX---o--->o-------o(B) (A) is one terminal of the temp sensor, and (B) is the other /Sonny
Internal name: "SuperSonic" -92 ebony black with 170k KM *** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. *** |
