Old 07-08-2004, 08:50 AM
Undertaker #59 Undertaker #59 is offline
Help diagnosing a problem
I saw the other AWD thread on here and not sure what to make of it. I am not mechanically inclined. Here is my situation:
I have four of the same tires on my 96. I noticed recently that the front tires are showing A LOT more wear than the rear. Also, sometimes when turning, there seems to be a stutter from the front tires as one seems to grab and slip in the turn.
Is there likely a problem?
If so, what is the likely problem and
How much is it likely to cost me at the dealer?
Also, my check engine light has ALWAYS been on since I bought this car. I had the dealer look into it once or twice and replace a sensor or something (O2 maybe) and clear, but it has always come back. I don't mention this to try to get it troubleshooted, I only mention it because I do not know if there is something with the AWD system that might have added something to the code since it is always on anyway.
Thank you for any help.
Old 07-08-2004, 09:10 AM
The stutter is likely Duty Solenoid C (AWD) sticking on and locking the car into 4wd (50/50)
You can check all your codes at http://svx-iw.com/
Old 07-08-2004, 09:37 AM
cbx-man cbx-man is offline
The un-even wear could indicate that your AWD is not working ( I had the same problem). ALL the power is going to the front wheels, thus the spinning inside tires on turns. One way to check is find some gravel road (or grassy area) and hit the throttle hard and spin the tires. If only the fronts tear up a nice patch then it's one of the solenoids inside the tranny.
After you get it fixed, you will need to get the rear tires buffed so they are the same circumference, otherwise you ruin what you just fixed.
cbx-man
'92 LSL Liquid Silver / Automatic Level-10 valve body mod / remote filter
'92 LSL Pearl White / 5 spd. IndigoSpeed 11# flywheel / ACPT Carbon fiber drive shaft
'80 Honda CBX in-line 24 valve 6 cylinder
Old 07-08-2004, 09:52 AM
Actually, the front tires are bad enough now that they need to be replaced.
Thanks for the help...what is this likely to cost?
Old 07-08-2004, 10:26 AM
Just a guess for tranny $3-400 max. if it's just a solenoid problem. Labor is the biggest chunk.
Buffing the tires approx. $15 ea.
The important thing is to do the tires FIRST.
cbx-man
Old 07-08-2004, 10:41 AM
svx_commuter's Avatar
Buffing the tires? I have been trying to find any place that will do that NJ area. I assume you are talking about removing tire tread so that tire stays round or is rounder. Right?
You still have places that do that? Every one around here got rid of there machines years ago..
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 07-08-2004, 10:43 AM
Undertaker, You may need a front end alignment too.
Old 07-08-2004, 11:07 AM
Yep, basically a belt-sander that removes tread to either make it round or just reduce circumference.
I will start a thread to help everyone try to find one in their local areas!
cbx-man
Old 07-08-2004, 12:34 PM
Mr. Pockets's Avatar
Moderator
Or, more likely, he just didn't rotate the tires. The fronts will always wear faster than the rears.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-08-2004, 01:49 PM
red95svx
Yep. Remember, AWD Subarus are mostly powered by the front wheels under normal conditions. We see this all the time:
Customer: "My front tires wear down sooooo fast!"
US: "When was the last time you had them rotated?"
Customer: "Rotated? They rotate every time I drive!"
Old 07-10-2004, 06:42 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
My AWD system works! I haven't rotated my tires for about more than 5000miles now. I can notice the front tires indeed wear down faster than the rear tires alot.
Is it also because the weight distribution is 59:41? The front-end of the SVX is not light too.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
