Old 07-07-2004, 07:34 PM
poweredx2 poweredx2 is offline
Blowing Hot Air
I have drained and refilled my a/c at least ten times,it gets cold now an then its hot again,this time I drained it and refilled the system and its still hot,tell me do I need a new compressor or what my 94 camry will blow your socks off with cold air I wish my svx would do the same.
Old 07-07-2004, 07:38 PM
nsm484's Avatar
nsm484 nsm484 is offline
Teh Geek
Send a message via ICQ to nsm484 Send a message via AIM to nsm484 Send a message via Yahoo to nsm484
Re: Blowing Hot Air
I dunno what to tell ya, the Prev owner of my svx replaced
the AC Unit to the newest standards, and ever sence i got it,
It blows cold air nicely... Specialy on Circulate mode
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker
2002 Mitsubishi Lancer OZ Rally [Nori]
1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling
1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone)
1992 LSL Ebony Mica (Sold to svxcuseme)
Old 07-07-2004, 08:03 PM
lee lee is offline
there are a large variety of things that can prevent cold air blowing, especially on the SVX - like the air mix door positioning.
you've probably posted before so please excuse my poor memory. Have you run the on-board diagnostics? Have you done the obvious checks (like the 1st question to computer users is have they checked to make sure the power plug is connected to the computer and to the wall), i.e., are you sure the compressor is turning and not just the belt, etc.?
The best diagnostic is generally done with a gauge set, reading the high and low side pressures, at around 2k rpm. Without that I don't know if anyone could tell you if it was the compressor or some other component.
Old 07-07-2004, 08:49 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Yeah, what Lee said!
Seriously, run the diagnostics for the HVAC system. When mine started blowing hot air I ran the diagnostics and found that the potentiometer on the baffle door was bad so the sytem wasn't letting the cold air circulate even though the a/c was cranking away - just got hot air from outside!
This said, I still haven't gotten around to fixing it....
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 07-07-2004, 08:54 PM
I just did the 134 conversion on mine last night, it was working fine but then today started blowing hot
My first thought was a major leak, but after hooking up the gauge that came with the kit, the pressure was HIGH almost off the gauge. After liberating some of the 134 and getting the pressure back down it is blowing cold again.
Old 07-08-2004, 04:59 AM
thats it
I have that same issue the pressure was in the red but after letting some freon out its still hot and what baffle door are you talking about.I watched the a/c unit the belt is turning but it appears to be something simple that is keeping the a/c from blowing cold air.
Old 07-08-2004, 09:05 AM
Does your A/C compressor cycle on/off?
Old 07-08-2004, 09:59 AM
a/c issue
No it don't cycle on and off,its never cool inside the car for it to cycle.I will check my sensors and cleaned everything today before refilling it.
Old 07-08-2004, 10:08 AM
Mr. Pockets's Avatar
Moderator
I don't really understand your symptoms, but tell me if this sounds familiar
My AC would work when it was cooler outside, but the hotter it got outside, the less often my AC would come on. Sometimes I'd get brief periods of cool air, but mostly it just wasn't working.
While doing some other work on the car, I had the radiator out and I noticed that the front of it was covered in road debris - leaves, bugs, stones, etc. I sprayed it from the back and flushed all that debris off the radiator.
Since then my AC has worked flawlessly.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 07-08-2004, 10:46 AM
svx_commuter's Avatar
I had just R134 installed almost 3 years ago and it's working fine.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 07-08-2004, 12:13 PM
here is the problem
My compressor is running my gauge with the recharge kit says my system is full but it continue to blow hot air.I will check what you told me also.
Old 07-08-2004, 12:32 PM
Moderator
Are you sure the compressor is running? If you have the car running and switch the climate control from econ to auto, you can hear the compressor turn on?
2005 Outback
END OF LINE
a/c problems
I washed the bugs from the front of the car and the air still blows hot. I'm taking this sob to the dealership tomorrow.I'm hot and pissed its 97 outside and 110 inside with the windows down and moving.
Old 07-08-2004, 12:35 PM
ITS RUNNING
I'm standing here looking at the compressor running and the clutch is engaged that run the a/c.
Old 07-08-2004, 04:46 PM
SVXRide's Avatar
run the diagnostics! if the variable potentiometer is shorted out you should still be able to get under the dash and jury-rig the baffle door open to let cold air flow...
-Bill
