Old 07-06-2004, 06:38 AM
Sonar's Avatar
Sonar Sonar is offline
Parts for XT ?
Does any1 know where to find parts (front driveshaft) for an old XT-4 turbo (-86) ?
Like subaruparts.com or similar.
My friend has a broken axle (spline gone), and has to replace it, he was wondering if the AT or Leone axle would fit, does any1 know it it does?
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 07-06-2004, 07:08 AM
The rear half is the same on all of the Soobs of that era (EA82 - XT6) the front half only varies in length depending on model and transmission. I have a strong feeling that other drive shafts will fit, just a matter of finding the right length (probably another with the same type of trans??)
edit: Just re-read your post, are you looking for the front half of the driveshaft (transmission to rear diff) or axle (differential to wheel)?? If you are talking about the axle, I think that the turbos had a higher spline count than the N/A's.
Old 07-06-2004, 07:20 AM
It will have to come from a turbo car with the same tranny Auto/Manual
Old 07-06-2004, 04:33 PM
Sonar's Avatar
Sorry if my english sux
I'm looking for the shaft/axle, from the front diff. to the wheel.
/Sonny
Old 07-06-2004, 07:10 PM
No Problem, It's much better than my Swedish
Some over at Ultimatesubaru.net use
http://www.cvaxles.com/
Not sure if they ship international or not?
As far as compatability, check out there reference sheet and match up part numbers.
Old 07-08-2004, 06:59 AM
Sonar's Avatar
Thanx
/Sonny
