lots of little questions
1. I have to hit my cruise button twice for it to come on. Is there a simple fix for this?
2. Something is scraping my windows. It is on the outside of the driver and passenger windows. There are to sets of scrapes down each one. What in the door could be causing this? 3. where is that how-to on cleaning the headlights. I cant find it in the new set-up. 4. What would cause my steering to pull right sometimes and then other times pull left pretty hard? 5. I am moving to virginia next year and was wondering if i should paint the car before i go. It is starting to rust slightly in a couple of places, but then again i dont want to put a nice paint job on it and have the icy salty roads in the winter eat it off. 6. What kind of paint can i use on the center caps on the wheels that will not come off in 3 days? 7.I have to give my sunroof a little bit of a boost to get it on its way. How do I fix this? 8. Why are you guys so awesome?lol ![]() thanks for the help |
Re: lots of little questions
![]() Quote:
If it is not there, I can give you an IP for that address. I am having some issues. Quote:
Lwin M. Maung (Member # 147) Current SVX: • NONE Previous SVXes: •1994 LE Barcelona Red 107k • 1992 LS-L Pearl White 143k • 1994 LSi Bordeaux Pearl 220k • 1992 LS-L Ebony Pearl 184k • 1992 LS-L Liquid Silver 145k • 1992 LS-L Liquid Silver 102k • 1992 LS-L Ebony Pearl 123k Other current cars:•2001 Jeep Grand Cherokee Black If at first you don't succeed, CHEAT!
Re: Re: lots of little questions
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() 2005 RX-8 Grand Touring 2005 Outback 2002 Mercedes-Benz E320 wagon END OF LINE |
Re: Re: Re: lots of little questions
thanks for the info. The link did not work so if you could give me the ip that would be great. a couple more 9. are the letters for the cruise area buttons supposed to light up. I swear one time it said cruise in green letters, maybe i was dreaming. They dont light up except for when they are on. And then the letters still dont light up its just a little orange light. 10. There is what appears to be a ground wire hanging down near the right exhaust tip. I can not figure out where it goes or what it does. any ideas? It has sort of a braided cover. 11. how do i get the condensation out of the rear tail lamps? |
Re: Re: Re: Re: lots of little questions
thanks for the help. Just trying to get the beast in good order while i have some free time on my hands.
Enjoy
If you go down a couple of pages, it'll tell you how to remove the little switches.
Thank you so much man. I am so glad to be a part of a community who cares.
I've been wondering about the purpose of this, as well. It's a flat, braided-wire grounding strap, maybe one-quarter inch thick, running from the right-side exhaust to a nearby frame member. Does anyone know? dcb |
you can 'clean' the track with some WD-40, but i'd recommend SilGlyde lubricant on track for lubrication. "stays put, water repellant, effective from -20deg F to +400deg F, prevents freezing, harmless to rubber, yada yada yada" good stuff
there are felt covered 'bumpers' in the top of the door panel that press against the glass. they get clogged up with gunk and scratch your window. i don't think they cost too much - you could order new ones or tie a piece of polar fleece around them with a zip tie. there are two per door.
Alan 1987 928 S4 (Black) 1997 SVX LSi (Ebony) 2005 Legacy GT (Silver) 1987 928 S4 (Black) 2008 Lancer Evolution X MR (Apex Silver) 2013 G37xS AWD(Obsidian Black) 2018 Q60 Red Sport AWD (Graphite Shadow) 2022 KIA Stinger GT2 Scorpion AWD (Aurora Black) |
after looking at the pdfs i have a couple more
Those are plasic headlights in the how to. I dont want them to be glass and then melt my plastic ones ![]() I read somewhere about using crome polish??? is the sanding nescicary or could i just use the chrome polish to get the yello film out? also what are all of those switches for below the head unit in the instrument panel pdf. I have a gap there and am processing some ideas to fill it. |
You can just wetsand from the outside. All the USDM SVXes have plastic headlights and they will not melt. I have done that more then enough times. But the reason why you take them apart is to repair the chips in the projector lense.
so is that yellow on the outside or inside
