Old 10-08-2001, 08:38 PM
SVX10's Avatar
SVX10 SVX10 is offline
Fighting with electricity
Question Tps
Does anybody know how to check the TPS. I believe I've found it (on driver's side of engine by throttle body?) but I don't know how to access the wires to measure the resistance. Any suggestions?
Mat-1
Old 10-10-2001, 08:30 PM
dromano's Avatar
dromano dromano is offline
Re: Tps
Mat-1
Pay a visit to your favorite tranny tech. Mine was able to change a shift point by adjusting the TPS. Should be able to answer your questions.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 10-12-2001, 03:46 PM
svx_commuter's Avatar
Re: Tps
Mat-1
There are three contact pins that are real hard to get too. I suggest mini alegator clips and long leads. But even with this it is a pain.
I matched marked mine and took it out. Then I check the resistance. But this is hard to do also. You are looking for the slightest change in resistance that is not consistant with the motion of the sensor.
I am buying a new one to run a comparison.
Old 10-12-2001, 04:00 PM
Re: Re: Tps
I turned my TPS up a little and it stopped a slipping problem I was having at light throttle load, slipping from 2nd to 3rd. I turned it too much the first time and the idle speed went up. About an 1/8 inch. Ended up turning it clockwise about a 1/16 inch.
Did your idle speed change?
Old 10-12-2001, 11:33 PM
SVX10's Avatar
I'm confused
I'm pretty lost here. I haven't done anything. Will turning the TPS adjust the tranny to eliminate any sort of shudder or just slippage. I'm not sure I understand just how it works. I know that it is a variable resistor, and I understand what you're saying about looking for any un-smooth changes in resistance, but I don't understand how it affects shudder or slippage or anything.
Old 10-13-2001, 12:58 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: I'm confused
Just for a little light reading, here's a thread where the TPS was discussed pretty heavily. Just thought it might help.
http://www.subaru-svx.net/forum/show...0&pagenumber=1
Randy Johnson
Mike Davis -- at Reading VI
