Old 02-05-2004, 04:49 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Subarus as Motorhome Dinghies
Now that I live in the mountainous part of the Southwest, I've started seeing quite a few Subarus being towed on the road behind motorhomes. These are fairly late-model Subies, so I know they're AWD.
Since every AWD Subie owner's manual I've ever seen is quite clear that Subies shouldn't be towed, I'm wondering - how are these guys doing this? Are they just saying screw the drivetrain, I'm gonna tow it anyway?!?!
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 02-05-2004, 05:01 PM
Mr. Pockets's Avatar
Moderator
Unless they're crawling under them each time to unbolt the prop shaft...
...actually, my Justy spent most of its life as a motorhome dinghy. Of course, it's FWD....
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 02-06-2004, 08:37 AM
red95svx
This is from a 2004 Baja owners manual:
"Towing with all wheels on the ground:
For vehicles with automatic transmission, the traveling speed must be limited to less than 20 mph, and the traveling distance to less than 30 miles. For greater speeds and distances, transport your vehicle on a flatbed truck."
So you can tow the car with all four wheels down, but it is not recommended. What Subaru does warn you about is towing the vehicle with two wheels on the ground and two off.
Old 02-06-2004, 08:52 AM
mark10t
I've had a bunch of Subaru's since 1981 and I had a GMC motorhome. I built a towbar at the time to use my Subaru as a 'dingy' (I used the tow eyes as attachment points for the tow bar). (I've still got the towbar and have used it for various 'emergencies' since with other Subaru's.) However, this was my '85 RX Turbo Sedan which had the 'on demand' 4WD w/ a 5-sp manual transmission. (My '87 RX had the full-time AWD). Worked great as a towable on a trip to CO one year (especially once when we ran out of gas in the MH!).
At the time, Subaru did not advocate towing at all, but they relaxed their stance in later years. I haven't followed since they went exclusively AWD.
There are some tricks you can employ to reliably tow AT vehicles- which should be applicable for AWD, too. One common practice is for a small hydraulic pump to be installed that assures transmission fluid gets circulated while towing to keep things cool and lubricated.
-Mark
Old 02-07-2004, 12:07 AM
NomadTW's Avatar
NomadTW NomadTW is offline
abrasive personality
Send a message via AIM to NomadTW
you can tow a MT subaru w/ AWD and all the wheels on the ground for as far as you desire if the transmission is out of gear
SV What?
Old 02-07-2004, 08:23 AM
Green1995SVX
That is correct.
Mike
Old 02-07-2004, 09:43 AM
sfsvx's Avatar
That explains it. Thanks for the info, guys.
Dick
2001 Outback Sport
