Old 01-08-2004, 08:03 PM
Brian's Avatar
Brian Brian is offline
Tansmission Cooler & Filter
Can someone tell me where I can get an external transmission fluid cooler and filter, especially at a good price? What can I expect to pay for each? Exactly what kind should I look for (specs and brand names)?
How often should the filter by changed?
-Brian
Old 01-09-2004, 12:25 AM
Brian
I have used the PermaCool filter (it has a port for a temp meter sensor) and there are a couple of coolers that are probably about the same when it comes to quality.
I got my parts from Northern Auto Parts. Their web site is at Northernautoparts.com. Phone is 800-831-0884.
Filter is about $35.00 and cooler is about $50.00. You can do a search to find out the different sizes and brands used by members.
Old 01-21-2004, 06:32 PM
does anyone know which ones will match up w/ our stock treaded lines?
Old 01-21-2004, 11:00 PM
For the most part, they all will, as long as they have a fitting that is the size of the hoses used.
Old 01-22-2004, 10:51 AM
mbtoloczko's Avatar
sans SVX
The stock lines for the ATF hoses aren't threaded, at least on my '95 SVX. Everything is held on with hose clamp type fittings. The fittings look factory issue.
Mychailo
Visit my locker
