Old 01-07-2004, 12:20 PM
Question auto trans compatability
Hi i own a 94 svx fwd. Now i have brought my car to my buddy who owns a transmission shop, not only has he never worked on one of these before but has no knowledge of the parts. Now it is aparent i will need a new transmission soon and i was wondering what other cars have the identical transmission. Now I know the 4eat was used in many cars i am talking about a direct bolt on. also i am pretty sure that the awd transmission can be used in a fwd model can anyone verify this for me. thanx for your response.
Old 01-07-2004, 12:44 PM
Mr. Pockets's Avatar
Moderator
I don't think an AWD transmission would work in a FWD SVX without at least minor modification, since the AWD tranny has the whole extension housing the transfer clutch and everything.
Having a FWD SVX means that you can probably use a FWD tranny from any FWD Impreza or Legacy because you don't have to match the diffs. But the gear ratios be the same as your original tranny and the clutches won't be quite as durable. They will bolt up, though.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 01-07-2004, 01:05 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
I am useing a 96 Impreza AWD tranny to replace my 92 SVX AWD one. it is a direct bolt in. I found it at a local salvage yard for $650.00, with the rear end too. A FWD one should work also.
Old 01-07-2004, 06:42 PM
imppow
the AWD tranny will work, just trade the tail shaft with the back of the front drive tranny. the axle ratios are going to be different from car to car. A AWD 90 legacy has a 4.30 ratio and a 92 AWD SVX has a 3.93 I think.
Old 01-07-2004, 07:54 PM
wawazat??'s Avatar
Yeah, I'm still around
Exclamation Watch the numbers you're throwing around here
Legacy final drive ratios can be 3.90:1 or 4.11:1 (front and rear).
The SVX (USDM) final drive ratio is 3.545:1 (front and rear). The SVX (JDM) is 3.70:1.
Imprezas (excl WRX) can be 3.90:1 or 4.11:1.
Forrester can be 4.11:1 or 4.44:1
WRX (manual) is 3.90:1 front and 3.545:1 rear.
Not sure about the auto WRX.
Todd
Down to none
Old 01-08-2004, 12:05 AM
svxsubaru1's Avatar
I thought we had the same deal as the wrx for the front/ rear diff ratio?
Old 01-12-2004, 10:15 AM
thats all great to know but what i need now is years and models of what trannies i can use.
Old 01-12-2004, 10:30 AM
Moderator
And I already explained that. Since you have a FWD SVX, I think you can probably use any FWD Legacy, Impreza or SVX tranny. An Impreza or Legacy tranny won't have the same gear ratios as an SVX, and the clutches aren't as beefy, but they will bolt right up. These guys are arguing final drive ratios, which you don't have to worry about as much because you don't have to match front and rear diffs.
2005 Outback
END OF LINE
Old 01-12-2004, 11:18 AM
mbtoloczko's Avatar
sans SVX
Not quite. The WRX is 3.9:1, but this is accomplished through a 3.9:1 front diff and a 3.54:1 rear diff and a 1.1:1 step down gear in the tranny for the rear drive.
Mychailo
Visit my locker
Old 01-12-2004, 11:30 AM
i need the years of the imprezza and legacy that are a match. I am sure that a 76 legacy isn't runing the same tranny.the ratios don't matter
Old 01-12-2004, 02:09 PM
wawazat??'s Avatar
It's not that simple. Ratios are broken down by model (Brighton, L, LS), transmisison type (auto and manual), engine displacement (1.8, 2.0, 2.2, 2.5, 3.0) and year.
Your best bet is to go to your local dealer and pull their service manuals for review. You could also pull covers and count teeth on the rear diffs and match them to the trans if you know the front diff ratio.
Good luck,
Todd
Down to none
Old 01-12-2004, 02:48 PM
Moderator
But there was no '76 Legacy. The Legacy, Impreza and SVX all showed up in Subaru's line-up within a couple years of eachother. The Legacy appeared for 1990, the SVX in 1992 and the Impreza in 1993. But it wasn't until the 1997 model year that all Subarus came with AWD standard.
So what you're looking for is a '90-'96 FWD Legacy or a '93-'96 FWD Impreza. Those are all the years that FWD models of those cars were produced, which is why I said any FWD Legacy, Impreza or SVX tranny.
The SVX was only built with FWD in '94 and '95.
2005 Outback
END OF LINE
Old 01-16-2004, 11:16 PM
i can also use a awd tranny as longas i swap out the tail shaft for the back plate on the fwd. so as long as the trannys bolt right up i just want to know all the years they were the same. sorry for being a pain in the ass but i don't want to buy a new tranny and not have it fit.thanx again
