Installing a trans cooler today with PICS
WIll post up pics tonite of the install we are doing
on a customers car..... I think its going to look rather nice
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
Heres how we what did
to me it makes the most sense and most
practical way to install a nice size cooler to any yr, model SVX. Step 1 remover the lower plastic engine cover
step II
peel back the plastic inner fender liner on the drivers
side wheelwell. Youll find plenty of room to install your new cooler... Youll see a few places you can attach the cooler marked in the pic....
Step III
Cooler kit comes with plenty of hose, self tapping bolts
and metal brackets. We installed a few brackets onto the cooler and adjusted and bent them to fit correctly up inside the wheelwell. We even used one of the factory bolts to the fender as an attaching point
at this angle
the cooler will get PLENTY of air flow thru the veins
and offer optimum cooling....
Next step
Mount your cooler, use self tapping bolts
supplied. It fits great, and very secure. Now your ready to route the new rubber lines to the factory lines around the corner. We have our Inlet line from the trans, going thru the auxillary filter mounted on the frame rail, out of that Into the new cooler, into the radiator cooler inlet, then back to return to the trans. Keeping the OE trans cooler connected is optional, but saw no reason no omit it at this time
connect the lines
a little more clearer pics
We ran the lines forward around the frame safely back alongside the framerail. We had everything inside out kit, didnt have to make one trip to the hardware store.
finally
re install large lower plastic panel
and we chose to cut out a nice opening in the stock wheelwell plastic liner. It helps scoop up lots of air and direct it right onto the new cooler. Job done total time about 2 hours.
Have you installed a temperature gauge to see how the cooler is performing in that location?
The one big concern I would have is that you have no airflow path for the cooler. Sure, it's in the open, but there's nowhere for air that's flowed through the cooler to go. I put mine in front of the AC condenser because I figured Subaru had already established nice airflow for me. Thanks for sharing.
it has plenty of flow
not to mention its not collecting any heat from other components and no need to remove the front bumper cover for installation. Temp before was about 240 during the summer, and it dropped to an avg 190-210 depending on traffic conditions. We did this on another car with gauge last summer, just didnt get pics of that set up.
Re: it has plenty of flow
2005 RX-8 Grand Touring 2005 Outback 2002 Mercedes-Benz E320 wagon END OF LINE Last edited by Mr. Pockets; 11-12-2003 at 03:43 PM. |
Dayle,
Nice job...I'm sure the pics will go a long way toward helping people do this mod in the future. Couple of questions: 1. What's the yellow box with the coiled wire coming out of it - part of your alarm system? 2. What's leaking in your engine bay? That had to be one of the dirtiest lower engine covers I've seen in a long time 3. Have you thought about covering the cut out section with some expanded metal? I'd be worried that a stray piece of "road trash" or gravel would take the cooler out. -B
Re: Re: it has plenty of flow
EXCEPT when your driving at speeds 30 mph + the Constant Force of air just from moving down the street is going to keep the cooler working. If you have a Fan blowing in the doorway and all windows are still closed, you still get cooled off, correct? Air doesnt get trapped into your wheelwell, or in your engine compartment. In the wheelwell it will travel thru and around the cooler then over the plastic liner to exit thru the rear of the fender. If need be you could even create more openings in the plastic to create more flow if desired Its also protected from road debris, rocks, bugs and snow over time.
system not sure It wasnt my car, its a customers car. I believe it was the trans line going into the aux filter. We installed a new filter, fixed the leak. The car had 75k miles on it. Thought about a open free flow mesh, but I think its high enough up and out of the way, doubt anything could damage it that easily, but its always an option.
All wiring, boxes and hardware for airbags seems to be yellow. I imagine that's because at the end of the wire is an explosive - even though that explosive is there for your safety.
