why you should install a higher pressure fpr
I've been looking doing a bit of research on the fuel delivery rate of our SVXes. Based on what I've found, it looks like the stock fuel system can handle no more than 230 HP without going lean at WOT. The stock injectors are 275 cc/min capacity (at 43 psi), and according to the service manual, the SVX fuel pressure is set to 36 psi at WOT. If I have a jaunt over to this page:
http://www.rceng.com/technical.htm and in the first worksheet use 230 HP, 6 injectors, a BSFC of 0.5, a duty cycle of 0.8, and a max fuel pressure of 36 PSI, then the worksheet spits out that 277 cc/min fuel injectors are needed for these conditions. That means that any aftermarket mods which improve airflow are going to be pushing the fuel delivery system beyond its limits. This would explain why svxfiles has been seeing improvements in power when he installed a 2000 Legacy 2.5 fuel pressure regulator which is good for 43 psi in his mildly modified SVX. Food for thought folks.
Worthwhile thoughts and info for sure.
But --- how do I REDUCE the gas my car uses when my wife hacks it about in city traffic etc ? The SVX has proven to be a hungry animal. Even so, it is quite a family pet.
At less than WOT, the ECU shortens the fuel pulse length to compensate for the higher fuel pressure.
so if you do any mods you should up the fuel to 43 PSI?
where can i get one and how much?
2005 Legacy GT 2002 WRX VF22, Pinks, big TMIC and turbo back 128,*** miles My WRX's Cardomain Page |
Indications are that many desire such improvement. Posting the obvious -- " Keep your foot off the gas ", will earn a booby prize.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 09-27-2003 at 12:12 AM. |
If that is a bolt in replacement then why do the guys putting turbos in the 2.5RS use an svx FPR? It would seem the legacy unit would be better.
And if this does pan out, don't throw out your old svx fpr - they are very easy to sell -even used- on the impreza forums. <---- heading over to nasioc tech forums
any one have a part number for the 2.5 FPR?
Mychailo,
Does this mean you're going to be the test mule for this mod? I'm in the middle of drawing up a new air box to allow for a larger drop in filter (stupid ABS keeps getting in the way ) so allowing for more fuel flow to go with increased air flow works for me! -Bill (definitely "keeping his foot off the gas" )
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
would some thing like this work
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2433517641 they say they have Fuel Rail Adapters for Subaru
- Rob |
or would it be better to go to a juck yard and just buy one off a 2000 2.5 legacy
