Old 08-23-2001, 11:44 PM
249SVX 249SVX is offline
still in love with Hannah
brake noise
Would bad bearings cause the brakes to squeal? Also, would the steering wheel shake when they are bad in the front?
silver 92 SVX-"Hannah" -R.I.P. NOV. 1991-jAN. 17, 2003
red white and blue 2000 Suzuki TL1000-r-"Bethany" This grips me more than a muddy old river or reclining Buddha.(now running Metzlers!
black 1987 Toyota MR2-"Helga" -Turbo conversion will now commence.
1996 Legacy Outback-"Gilda" white with brown trim
Old 08-23-2001, 11:50 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Re: brake noise
I am not an expert but bearings will have growling noise not a squeal. Squealing sound comes from worn pads/rotors. Check the wear on them. Shaking steering (when breaking) probably means your rotors are wrapped. Have them cut if you still have some more room. Otherwise, replace them.
If you are replacing them, get organic pads while you are at it. They takes longer to break but they do not squeal.
If the car is shaking while normal driving, have the tires rotated and balanced. That should do the trick.
Lwin
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 08-24-2001, 08:15 AM
Re: Re: brake noise
Lwin
I do have the growling. The pads are about a month old. My front brakes will squeal sometimes when braking, sometimes very loud. The steering wheel doesn't shake at all when braking , only when driving. It gets better after I drive it awhile but it is still there. I had just recently replaced the hose that goes to the master cylinder a it sounded like it helped to keep them quiet. I've been pondering this problem for nearly a year now.
Old 08-24-2001, 08:22 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Re: Re: brake noise
My guess is that you used aftermarket pads. You'll find that A/M pads have more of a tendency to squeal than OEM.
There are several things that could be causing your shaking in the steering wheel. If it levels off after driving, I'd suspect the tires, but, would have the front suspension fully checked, for safety's sake.
Randy Johnson
Mike Davis -- at Reading VI
Old 08-29-2001, 10:15 PM
picklesbitch
Re: Re: Re: Re: brake noise
Just to point out something a little different, my brakes were squealing to beat all hell 3 years ago. Original brakes on a 92. I changed rotors and pads, Subaru pads and rear rotors, NAPA front rotors(availability of NAPA was next day Subaru next week and I was moving.) It was embarassing to be seen in the car while braking before the change. There was still plenty of material on the stock pads, so I wouldn't always attribute squealing to AMs. I also changed out the brake fluid at the time, pretty simple to do.
Mike
Old 08-29-2001, 10:58 PM
Re: Re: Re: Re: Re: brake noise
I just got the car inspected and was told that I needed new cv boots. Aparently they are cracked and grease is slinging everywhere. So that might be some of the shake.
Old 08-30-2001, 11:11 AM
svx_commuter's Avatar
Re: Re: Re: Re: Re: Re: brake noise
Bad CV joints will make the front end shake. I put in new Subaru axles, that's the whole assembly from the wheel to trans, in my car for $150 each. If the shake has been going on for awhile it may have damaged the tie rod ends. Bad tie rods will allow the front to shake, bent rims also. You can check out the wheel bearing with a dial indicator.
Old 08-30-2001, 11:17 PM
Re: Re: Re: Re: Re: Re: Re: brake noise
Oh man, don't say that. Well, fortunately, the mild shaking only started a little while ago(about 3 weeks), so I'm hoping that it's just that the grease is unbalanced and causing it(crosses fingers).On a related note(to this thread), I replaced my vacuum hose for the master cylinder with a piece of hose from the tranny filter kit I purchased. The squealing is all but gone now except for when I drive in the city and the brakes have a chance to get good and hot. Also, they aren't spongey like they were. The only bad part about it is there isn't a replacement hose in the country at this time.
Old 08-31-2001, 11:48 AM
EveryShadeofBlue EveryShadeofBlue is offline
British Car Junky
Send a message via AIM to EveryShadeofBlue Send a message via Yahoo to EveryShadeofBlue
Talking New pads
While the aftermarket pads I bought about a year and 3 months ago aren't worn and work well, they squeal like crazy. I just ordered OEM pads and will be putting them in this weekend. It's SOOOO embarassing to make so much noise when braking, especially when you are trying to impress people!
Jeff
Jeff - Tampa, FL -
Old 08-31-2001, 04:22 PM
Lowered SVX
the shaking you feel could be.....
warped rotors. how is the alignment on your car? does the car shake everytime you come to a stop? only during hard breaking? just trying to get an idea of what exactly is happening.
"Too much fun to drive!"
Old 09-01-2001, 09:23 AM
The shaking is very...
mild. It's worse on cooler days or when the car has been sitting for awhile(I attribute it to being cold tires). However, when they warm up, it still has a very slight shake to it. I just had the car aligned again, although it is still pulling to the right, which tells me they didn't align the damn thing worth a crap. I have no shaking during braking, except when I have to aviod the occasional cow or deer. One thing I have noticed is the pads do put out a LOT of dust.
Old 09-01-2001, 01:43 PM
eddycat2000's Avatar
eddycat2000 eddycat2000 is offline
Dumba$$ Mechanic
An alignment lesson...
Alignment techs put the car back to original factory specs. They can not adjust tire problems, nor can they (on a Subaru) adjust caster. Guess which side of the car will pull...the side with the most negative caster.
So before you go saying the alignment shop did a crappy job...didja align it with new tires? Didja try swapping tires front to back (or for just a test side to side)? Was the tech able to put the thing back in factory spec...or do you have a bent part?
Are you feeling the normal pull associated with the crown of the road. You *do* realize that roads aren't flat right? In the left hand lane the thing will drift to the left, and in the right hand lane, the thing will drift to the right.
Frankly guys, there isn't a whole lot of aligning that can be done anymore...not like the olden days when cars used shims. You may have a whole different problem than alignment causing your pull. I have on many occasions had to take customers out and show them that what they are feeling is normal. (And yes, even after showing them..."well my toyota don't do that".)
Pull my finger!
Old 09-04-2001, 10:57 AM
Re: An alignment lesson...
Well, it pulls to the right even when I'm in the left lane. I had the tires rotated (I think they just moved them from front to back) and it still pulls left. I am rather hesitant to swap them from one side to the other, they are monodirectional tires, but I will try it tomorrow(if'n I get up early enough)
They were able to get it back to factory specs, and it drove nice and straight, then I hit a bump(big pothole) and knocked it out of aliagnment. This was in February of this year when I got new tires put on.
About the vacuum hose for the master cylinder. What are the valves for in the hose?(They look like valves at least)
