Old 08-26-2003, 11:16 PM
Myata1
How to tell a FWD from an AWD?
At first glance? Is there a rule of thumb? ABS=AWD? I would have said cloth=FWD but apparently there was a ABS/AWD package available. What years was FWD available?
So far Search has gleaned the:
Transmission- Listen for slippage. Sniff the fluid after it is hot.
Wheel bearings- Listen for the humming/grinding noise.
Brake rotors- Could be warped..... does it shake on braking?
Leaks, noises, etc.... such as you look for used car shopping.
Anything else I can't think of right now?
Hopin' to join y'all real soon.
Brian
Old 08-27-2003, 03:26 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Excuse me if I'm stating the obvious
The best way to tell if an SVX is FWD or AWD is to look under the back of the car and see if there is a differential and drive shafts connected to the rear wheels.
Old 08-27-2003, 09:06 AM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
Re: Excuse me if I'm stating the obvious
Cheater!
Old 08-27-2003, 09:50 AM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
94 and 95s are the only time they offered FWD. 94L SVXes are ALL FWD. 95L can be FWD or AWD depending on the package it came in. The best way to tell is take a peek underneath the car like b3lha said.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 08-27-2003, 10:19 AM
Green1995SVX
additionally, all 94 and 95 LS models are fwd.
Mike
Old 08-27-2003, 10:45 AM
alacrity024
or you could mash the gas from a stop and see if it spins tire.. 230hp and ~230ft/lbs works out to a pretty easy set of front wheels to spin..
-adam
Old 08-27-2003, 12:04 PM
wasions's Avatar
wasions wasions is offline
SVX Black Belt Master
Pick it up by the tail. The AWD is the one with the 'thing' under there.
Steve
'95 Polo Green SVX L AWD, 188K - "Kermit" (Gone, but not forgotten)
'02 Outback LLBean, 56K
'02 Black Sapphire Volvo V40, 133K - "Shadowfax"
'06 Triumph Tiger, 19K
'99 Suzuki DR350SE, 8.5K - "Geezer Killer"
Old 08-27-2003, 12:17 PM
Seraph's Avatar
One of my neighbours was looking to buy an impreza a couple of months ago. He wanted to know if it was AWD for FWD. I cheated and looked underneath to discover that it had no thingie and had to come to a conclusion that it's a FWD impreza.
L
Current SVX: NONE
Old 08-27-2003, 01:38 PM
calmone
put it one a lift and gun the engine, saves bending over.
Old 08-27-2003, 02:05 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
If it's owned by an anally retentive engineer, it must be AWD
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 08-27-2003, 05:12 PM
Limp wristed way.
If you have a bad back,or you arn't strong enought to lift its tail. Have a look for the FWD fuse.
Old 08-27-2003, 06:41 PM
nordique14's Avatar
Who watches the watchmen?
Even easier is to look under the hood for the ABS module. It's clearly labelled and easy to find. FWD does not have ABS. All AWD have ABS.
