Old 06-11-2003, 03:32 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
Transmission Temp Sending Unit
Finally have all parts in hand to install a tranny temp gauge. Only question is where to mount the sending unit. Benebob had a good looking pillar mount gauge, but I forgot to ask where the sending unit was installed!
Any tips/photos are much appreciated!
Dave W.
______________________________
1996 Redd
Old 06-11-2003, 03:41 PM
Mr. Pockets's Avatar
Moderator
Re: Transmission Temp Sending Unit
I plan on mounting mine in a Perma-Cool ATF filter kit. The filter bracket is set up to have a temp. sending unit inserted into it.
I tried to just find some brass pipe fittings at Home Depot, but nothing really worked.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-11-2003, 04:07 PM
That is the best way to mout it (in the filter head) and the easiest way as well. Good luck.
PS - I have some pictures in my locker of the installation.
Old 06-11-2003, 04:31 PM
Moderator
Is there any way to mount it without drilling holes in the car, I wonder?
2005 Outback
END OF LINE
Old 06-11-2003, 05:41 PM
wynndi's Avatar
I forgot to add that my SVX is a '96.
Dave W.
1996 Redd
Old 06-11-2003, 06:10 PM
lee lee is offline
3 ways at least I know of
1. Buy and install an aftermarket filter kit as mentioned earlier. May require drilling holes to mount the filter.
2. I picked up a 1/4" NPT threaded "T" and 2 hose barb fittings the same size as the ID of the transmission lines ( I forget is it 5/16" or 11/32") at my local Ace Hardware for about $2 total. Then all you have to do is cut the tranny hose on the inlet side to the cooler in the lower radiator (have a catch basin for fluid that will leak out), and put the hose barbs into the ends of the line you just cut.
3. What I think is the preferred method. Take off the tranny pan and have a hole drilled and install the fitting in the pan itself. That's where the OEM temp sender picks up for the hot ATF light. Don't try to do on car as metal shavings from the drilling will end up in the fluid no matter how careful you drill.
all three of these methods don't address running the sensor wire, but that's a whole nother issue.
Old 06-11-2003, 06:13 PM
Duct tape? wire? I didn't think that drilling 2 holes in that location was all that bad. It ususally kills me to drill any holes into my cars!
Old 06-11-2003, 07:25 PM
immortal_suby's Avatar
Thread Killah
Drill??// Ack - no way. There are 2 nice holes in the drivers fenderwell which work nicely to mount the filter kit. Pics in my locker. There are also holes that can be used where the dealer would mount the tsb filter kit. I used those for my wife's svx filter kit. No drill bit shall come near my car unless it is to install the 5spd.
Locker Link
2015 BRZ Limited 6MT
Old 06-11-2003, 08:22 PM
Moderator
Re: 3 ways at least I know of
Not my preferred method, at all. The oil in the pan, while physically touching the tranny itself, gets there after it has run through the cooler. I want my temp gauge to accurately reflect the real temperatures my tranny is seeing, not a best-case scenario after the cooler has done its work.
This means, in my opinion, that the temp sensor should be as close to the out pipe on the tranny as possible.
2005 Outback
END OF LINE
Old 06-11-2003, 08:23 PM
Moderator
Yopu were able to find a T that put the sender in contact with the fluid, but left a big enough opening for the fluid to get through? I couldn't find one.
2005 Outback
END OF LINE
Old 06-11-2003, 08:50 PM
lee lee is offline
Re: Re: 3 ways at least I know of
Maybe I was just lucky with the combination of parts. The T worked just about perfect with the parts that came with the Hayden gauge I bought along with a Hayden stacked plate cooler (they use the same OEM as B&M).
The fluid path inside the T is bigger than the ID of the hose. I'd guess something just over 1/2" bore inside the T. The external size of the T is over 2" in length and almost an inch in width. The end of the sensor protrudes a bit into the flow, but given the size of the bore where it's at I see no problem with obstruction.
To each his own for the sensor location - probably much like the series or parallel discussion on cooler location. I too went with the line coming out of the TC thinking that would be the hottest spot I could easily measure. However every OEM and gauge maker I've seen recommends the pan - excepting those that sell the external filter kit of course. I always (probably incorrectly) assumed that was so you measured the temp of the fluid the tranny was picking up (which should be about 150-170F) vice what it was kicking out.
Old 06-12-2003, 08:59 AM
Moderator
Re: Re: Re: 3 ways at least I know of
But if you're measuring the temperature of the fluid that the tranny is picking up, then you're not getting an accurate reading of the actual fluid temperature inside the tranny - since it's obviously going to be warmer as it leaves the tranny. That's my argument.
I'll have to keep looking for the pipe fittings - I'd like to install mine the same way you installled youres. Any chance you could post some photos?
2005 Outback
END OF LINE
Old 06-12-2003, 09:49 AM
Zeppelin's Avatar
Zeppelin Zeppelin is offline
Send a message via ICQ to Zeppelin Send a message via AIM to Zeppelin Send a message via Yahoo to Zeppelin
I used a brass T for my sending unit, here's a pic..
I'm like a Slinky.. Not really good for anything, but you can't help but smile when you see me tumble down the stairs.
http://stickyvinylgraphics.com/
Old 06-12-2003, 09:51 AM
Moderator
Awesome - thanks!
2005 Outback
END OF LINE
Old 06-12-2003, 09:54 AM
Zeppelin's Avatar
NP, Nick.. What I did was I took the sending unit into Valu with me, and found a Brass T that the sending unit would screw into.. Then, I had to get 2 female reducers for each side (I think it was 3/4" to 1/2", then 1/2" to 3/8").. Screw em all together with some locktite and you're all set!
Oh, Don't forget to crimp the tranny lines with some hose clamps so you don't get a shower!
