Old 05-29-2003, 02:03 PM
Porter
Help! My alarm freaks out!
I'm having some alarm issues.
The system seems to work normally 99% of the time. Red blinky light on the dash, etc. Arm/disarm is the normal honk and honk-honk. Turning the alarm system on and off via the dash switch is normal. Man, that blinking light is annoying when you're driving. The entry alarm feature seems normal, if you unlock the door with the key and open it, all hell breaks loose.
The issue occurs randomly... and it manifests itself in one of two ways.
First, the alarm will set itself off for no apparent reason, as it just did outside my apartment. I can see it from the window and there was no-one around it when it began to honk and flash the lights, etc. It took three tries with the remote to make it stop freaking out. The alarm function itself seemed normal, flashing parking lights and honking in a shifting pattern.
The other manifestation is more bizzare... it involves quick patternless half-honks, rapid flashing of lights and LOTS of rapid relay clicking behind the dash from several locations. It did this once outside my work by itself, and once about a month ago while I was driving down the road. All the dash lights including the backlighting and illumination were flicking on and off fairly rapidly and evenly during this episode, but the engine seemed unaffected. I was able to return the system to normal by locking the doors with the remote and then unlocking them... while driving! Weird stuff.
Anybody have any clues? Should I call for a priest and send out for holy water?
Old 05-29-2003, 03:38 PM
mbtoloczko's Avatar
sans SVX
Have you tried resetting the alarm module either by disconnecting the battery negative or unplugging the module itself?
Mychailo
Visit my locker
Old 05-29-2003, 07:38 PM
immortal_suby's Avatar
Thread Killah
I am pretty sure the light does not blink while driving in either of our svx's
Locker Link
2015 BRZ Limited 6MT
Subafreak's Avatar
Superbeast
SVXtine?
Old 05-29-2003, 08:30 PM
lee lee is offline
Re: Help! My alarm freaks out!
...snip...
...snip
I never had a working factory alarm, but has the glovebox been out recently? I'm asking because there's a sensitivity knob that could have been moved - possibly enough to have it go off with breezes from passing cars or sonic booms or ??? I realize this is pretty far out there, just a thought.
Old 05-29-2003, 08:52 PM
mbtoloczko's Avatar
sans SVX
Re: Re: Help! My alarm freaks out!
Porter has a '94 SVX, so his alarm module is in the trunk attached to the bottom side of the speaker deck.
Mychailo
Visit my locker
Old 05-29-2003, 09:00 PM
lee lee is offline
Re: Re: Re: Help! My alarm freaks out!
My bad for not looking, but I assume it still has a little phillips type knob for sensitivity adjustment, yes/no?
Old 05-29-2003, 09:18 PM
mbtoloczko's Avatar
sans SVX
Re: Re: Re: Re: Help! My alarm freaks out!
Yep.
Mychailo
Visit my locker
Old 05-30-2003, 05:20 AM
svx_commuter's Avatar
Got rodents?
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 05-30-2003, 11:08 AM
Porter
Whoa... so is mine freaky?
When the system is on it blinks whether you're driving or not, this is with the alarm disarmed (honk-honk unlock).
If the system is off it shows no light, and you get the chirpety-chirpety lock/unlock.
Can anybody verify this?
BTW, thanks for the responses guys! I'm working to track it all down...
I'll check the sensitivity next, but I'm pretty sure it doesn't have an impact sensor or anything. I can jump on the rear bumper with it armed and it won't go off. If I open the door though, bam it goes off. Seems to be only an entry alarm.
Old 05-30-2003, 11:09 AM
Porter
Originally posted by svx_commuter
Got rodents?
Yes, actually... a bunny. My GF loved your post.
Old 05-30-2003, 11:24 AM
mbtoloczko's Avatar
sans SVX
Wow. I thought you were joking about this! The light is supposed to turn off when the car is running.
[/QUOTE]
Its supposed to have a motion sensor too.
Did you try unplugging the module yet? Its pretty easy. There's an access panel in the roof of the trunk.
Mychailo
Visit my locker
Old 05-31-2003, 07:25 PM
Porter
Hmm....
I haven't unplugged it yet, but it seems there is a cut wire in my trunk! It's a thin grey one by itself running up the left (driver) side of the compartment.
I'll do the unplug/reset tomorrow and see if that helps anything.
