Old 05-04-2003, 03:48 PM
DavieGravy DavieGravy is offline
Rotor puller
I was doing brakes today and couldn't get the rotors off. Where can I get a puller, do I need one, and are they expensive?
I know that some screw from the radiator fits but I wasn't sure if I need an actual puller or just a couple of screws.
Thanks in advance.
Out for good.
Old 05-04-2003, 04:20 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Davie,
Look closely at the rotor and you'll see two threaded holes. They take 8mm bolts -- about 1.25 " long should do the trick -- screw both in and make sure you tighten them in equally to push the rotor off. Make sure you get grade 8 bolts or better (got mine at Home Depot).
Good luck.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 05-04-2003, 04:33 PM
Thanks very much Bill.
Out for good.
Old 05-05-2003, 05:55 AM
svx_commuter's Avatar
It is a good idea to clean off the hub with a wire brush and maybe use some penatrant on the hub before pulling it. The hub locates the disk with a tight fit and this can prevent it from coming off.
Old 05-05-2003, 08:43 AM
kuoh kuoh is offline
First, if you're doing the rear rotors, make sure you don't have the parking brake engaged. Second, the bolts that hold the upper radiator brackets are a perfect fit for the threaded holes in the hub. The rotor should pop off within 3 or 4 turns of the bolts.
KuoH
Old 05-05-2003, 09:16 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
KuoH
Or you'll break the radiator bolts off in the rotor like I did
From now on, I'll buy strong bolts instead of improvising.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 05-05-2003, 09:52 AM
SVXRide's Avatar
Doug!
I'd have sent you my grade 8 bolts
-Bill
Old 05-05-2003, 09:57 AM
wawazat??'s Avatar
Yeah, I'm still around
Talking I've also used the BFH
Big Frickin' Hammer (actually a 3# dead-blow, rubber mallet). It makes a wonderful persuader.
Todd
Down to none
Old 05-05-2003, 09:59 AM
mattski mattski is offline
It might help to clean the threads in the rotor using a tap. If you do not have one, spray a lot of lubricant into the holes, and thread in the bolts gradually, in and back out. If you feel a lot of resistance, back them out completely, flush out the accumulated rust, and try again.
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 05-05-2003, 10:59 AM
how about some PB Blaster - that stuff is great.
Old 05-05-2003, 12:15 PM
Yours must have had some serious rust. The one front and one rear rotor that did need this persuasion when we did it presented little resistance to the bolts, even though they wouldn't budge at all with the little hammer we had on hand.
KuoH
Old 05-05-2003, 03:03 PM
Thanks for all the input. It's occurred to me that the rotors have been cut twice and probably can't be turned again. So I replaced the pads and cleaned everything with brake cleaner. Also, I did try bashing them with a rubber hammer to no sucess. But next time I need to pull them off, I think I'll be able to manage.
Out for good.
Old 05-05-2003, 05:51 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Re: I've also used the BFH
Todd
I also use a 3# BFH, all steel. Anything I hit with it is bound to die, so I guess you could call it a 'dead-blow' hammer. I have yet to find a drum or rotor that could resist its persuasion.
Old 05-05-2003, 07:00 PM
Chicane Chicane is offline
Anti-BS Vigilante
Uh... the rotors have screws?!?!?! I replaced all 4 rotors on my SVX, and there weren't 'screws' holding any of them on. What I had to do was undo the caliper, then sit on my ass and KICK the rotor once or twice, then it just comes right off. Do 92 LSLs have these screws?! Anyway, my brakes work fine.
- Rob
Old 05-05-2003, 10:01 PM
They don't have screws, they have screw holes. Two of them, such that one can screw in bolts to push the rotor off if it's being stubborn.
By the way, I tightened down those (pivot?) bolts really f***in hard and no more front end noise. Pretty happy about that.
Out for good.
