Old 06-10-2011, 08:17 PM
Rolling92SVX Rolling92SVX is offline
Alternator??
I just bought brand new battery and battery ends for my car and it still only charges at 11.7 volts when i drive and dies down when i stop. whats the issue? is my alt. taking a ****?
Old 06-10-2011, 10:52 PM
Re: Alternator??
Based upon your information, I would say that your alternator is definitely on its way out. Normal charging voltage should be in the mid-13V range or higher with the engine running. At 11.5V, the alternator ceases to charge the battery.
Is it the original alternator?
Are all of the battery cables, including the ground wires, cleaned and securely tightened?
Do the idiot lights in the dash glow dimly while idling? Is the alternator belt tight?
Anyway, the cheapest and best source for an SVX replacement alternator is HERE
After you return your old core for a $60.00 credit, your final price is only $89.00. The core return is paid for by the company and the new alternator comes with a 2 year hassle-free warranty.
If you order online or by phone, mention the coupon code 4747 for free ground shipping of your new alternator. If you call, speak with Christian. This company is the best!!
Old 06-10-2011, 11:14 PM
Re: Alternator??
Could possibly just be the crank pulley separating. The test for that is free: http://www.subaru-svx.net/forum/show...72&postcount=4
Old 06-11-2011, 09:13 AM
Re: Alternator??
Mark your pulley and drive it around for a while.The marks should stay aligned.
Lower photo for reference only; the lines could be at any distance from each other indicating that the front and rear parts of the pulley are not securely attached to the rubber separator between the two
Old 06-11-2011, 10:37 AM
Re: Alternator??
everything is tight. looks like its time for a new alt. thanks for the help
Old 06-13-2011, 02:25 PM
Re: Alternator??
Where were you measuring the voltage from? Was the engine at idle? Did the voltage change with RPM? Can you find a place that will check your alternator for free?
Old 06-13-2011, 03:25 PM
Re: Alternator??
If you remove the alternator from the car, Autozone or Advanced Auto will test it for free.
Old 06-13-2011, 05:18 PM
kwren's Avatar
kwren kwren is offline
Re: Alternator??
Following the advice of the people on this site that know how to test an alternator will turn out to be more accurate than most of "those people"
If your alternator output is fluxawating, as they sometimes do, charge great and at other times, not charge so good, taking it to get it tested wouldn't necessarily help you at all.
You have pretty much nailed it already as you do not have to increase the rpm to get more than 12 volts if the alternator is working. Your 11.5 is undoubtedly the existing battery voltage.
Keith
Old 06-14-2011, 11:49 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Re: Alternator??
From past experience, I had my alternator tested off the car and they were fine. But when it was tested in the car it was bad. It was bad connectors!
Old 06-30-2011, 05:09 PM
Re: Alternator??
are you saying a loose or possibly cracked belt will cause the dash lights to glow dimly only while idling?
