Old 05-07-2011, 05:08 PM
XxMattrimxX's Avatar
XxMattrimxX XxMattrimxX is offline
Need help! I have a knocking sound!!!!!!!
here is what i mean:
http://www.youtube.com/watch?v=eR0PbHoenzs
Old 05-07-2011, 06:25 PM
radarwhiz's Avatar
Fairmont State University
Re: Need help! I have a knocking sound!!!!!!!
Sounds just like mine that had a spun rod bearing right before it blew up.
Sorry, don't mean to scare you.
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 05-07-2011, 06:45 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Sounds like mine like almost all the time. Normally I just add oil and it stops.
Old 05-07-2011, 06:49 PM
Cam Cam is offline
Make sure your power steering pump is full of fluid. If you have a leak and it is dry it can make an extremely similar noise.
Hopefully it is not a bearing... good luck.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 05-07-2011, 07:30 PM
You think its the PS pump?! I figured it would be a heat shield or perhaps and bent rod....
Old 05-07-2011, 07:32 PM
Oh and the PS res is full. Im no fool. I keep all fluids at peak and check them regularly.
Old 05-08-2011, 06:07 AM
michael's Avatar
michael michael is offline
What Potholes ???
What octane fuel are you running and when was your last oil change? What weight/brand oil. As of now I see Seafoam in your future
Wanted: Steering Wheel
Old 05-08-2011, 06:12 AM
Kinda scaring me a bit lol!
My last oil change was <1500 miles ago with a 5w30... quaker state? ...high milage half synth (to see if it smoked at start up still, otherwise its full synth) and I uses 91 premuim at QuickTrip only! What is Seafoam? Is it expensive? (edit: looked up seafoam video http://video..com/videoplay?docid=6187290865726229173# and I gotta say aside from the smoking it looks pretty solid)
Old 05-08-2011, 07:43 AM
Freeman's Avatar
Unregistered User
5w30 is probably your problem. Should look in a recent oil weight thread wherethe best suggestions for oil in our car were made.
Also, I used seafoam in my car and nevr listened for the knocking or if it went away after that. It may have.
Old 05-08-2011, 08:02 AM
Hey I know the weight differences and what they are good for, but i changed the oil twice in less than a month because i did the first one and then had to replace the valve cover seals along with oil again. It was still cold cold when I put the oil in, and it got to -11 in MO this winter. with a **** ton of snow too lol. pic as proof:
Old 05-09-2011, 07:04 AM
Hmm, this is a slow weekend on the forums! Everyone must be out driving, too busy to answer a poor man's troubles.
Old 05-14-2011, 07:00 AM
BUMP!!!!
I still needs helpsss!!!!!!! PLZ!! Need expert opinion!!!!! TYTYTYTYTY!
Old 05-14-2011, 08:45 AM
Does the sound change if it is in park/neutral, or in drive?
Old 05-14-2011, 10:24 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Sounds just like the engine I pulled out of the Pearly. 8mm, 10mm, 12mm, 14mm, 19mm. Remember: There are no big jobs, just bunches of small ones.
Old 05-14-2011, 11:01 AM
No change between gears or directions. Only when warmed up does it stop.
LetitSnow - What was wrong with the engine you recently pulled? Im looking for that sort of speculation here.
