Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Engine Management
Old 05-05-2011, 06:49 PM
Numbchux Numbchux is offline
Megasquirt?
I see there was a post here a few years ago that didn't really go anywhere....anyone done it? or know Megasquirt well enough to say whether it'll work?
Old 05-05-2011, 07:47 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Re: Megasquirt?
It would work, no problem, for air and fuel. The ignition is the tricky part...I'm not sure if anyone has figured out how to use the stock crank sensors with Megasquirt. I have not looked at this for some time though, so by now it may have been done.
I once megasquirted an XT/4 turbo but that already had a distributor so no ignition stuff was required.
It's a lot of fun and interesting to figure out the maps, etc..
http://www.megamanual.com/forums.htm
link to all the forums..
If you figure out the ignition, please let us know...
'20 Honda Ridgeline
http://www.x35design.com
Old 05-06-2011, 12:41 AM
Re: Megasquirt?
As long as you can calibrate the sensors, you can use the newer megasquirts with whatever you want. It has been done by someone with an EG33 in a 2.5RS, but not in a well documented way, and the people who put the car together have since sold it, so probably not much help now.
Old 08-30-2011, 06:20 PM
dynomatt dynomatt is offline
Re: Megasquirt?
I've done it.
Happy to answer questions.
M
Old 08-30-2011, 06:53 PM
Re: Megasquirt?
Did you use the stock sensors?
Especially want to know about the ignition stuff.
Old 08-30-2011, 06:56 PM
Re: Megasquirt?
I think I've posted this before.
yes all stock sensors. Modified the 12 tooth CAS to become a 12-1 and it works perfectly.
Having some dwell issues though, so will fit newer coils in an attempt to fix that.
M
Old 08-30-2011, 07:00 PM
Re: Megasquirt?
CAS is crank angle sensor I'm guessing. Is that # 1 or 2? So you removed one tooth or what?
Old 08-30-2011, 07:11 PM
Re: Megasquirt?
Yes crank angle sensor. There's 2, but it's the 12 evenly spaced tooth one. Then took off one tooth and told MS where that tooth had been. Uses it as a reference.
Old 08-30-2011, 07:44 PM
Re: Megasquirt?
Interesting. I have only just scratched the surface of the MS stuff. Any way I could get you to post what you've made? Or maybe email it to me so I can have a look at it?
Old 08-30-2011, 07:45 PM
Re: Megasquirt?
Post what I've made? do you mean in relation to the CAS wheel?
Old 08-30-2011, 08:03 PM
Re: Megasquirt?
No I mean like the maps or whatever you edit on the computer to put on the MS.
(Sorry if it's really obvious that I have no idea how it works on the software side.)
Old 08-30-2011, 08:04 PM
Re: Megasquirt?
Oh right.
I can post the maps tonight.
I just use the regular MS tuning software.
M
Old 08-30-2011, 08:07 PM
Re: Megasquirt?
Cool. Thanks.
*hoping that you can open the maps in Tuner studio without a MS attached*
Old 08-30-2011, 08:08 PM
Re: Megasquirt?
Yes you can open them...
