Old 05-01-2011, 07:52 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
front drivers window wont go up.
My front driver's window is stuck down and the switch panel is screwed. Can someone please explain to me how to get the window up so it doesn't stay open all night.
I has teh FWD LS-L
Old 05-01-2011, 08:47 PM
K_Dub's Avatar
K_Dub K_Dub is offline
Headin' for the hills
Re: front drivers window wont go up.
Pop off the door panel. You'll see the motor assy. with a wiring connector that then leads to the door switch. If the motor is good, but switch bad, you can disconnect the motor and jump +12V to the leads on the connector from your battery with the neg side grounded. You'll effectively bypass the switch, fuse, everything, so make sure you disconnect when the window reaches the top because the auto-off won't work. That should seal it up for the night.
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner
Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor
Buying parts is like car payments. Someday she'll be all mine.
Old 05-01-2011, 08:57 PM
92_LSL's Avatar
Thanks man, I really appreciate the reply. I just got the window motor today from a junkyard. I put the motor in and it went down and never went back up.
I has teh FWD LS-L
Old 05-01-2011, 10:19 PM
K_Dub's Avatar
Is there an Alan head on the motor you can crank it up with? I'd want to test it electrically though, cause cranking it all the way closed would suck.
Old 05-02-2011, 09:22 AM
kinz kinz is offline
My passenger side switch is picky. It goes down great, but usually wouldn't go up using driver side button. I did however find out that if you press down on the pivoting end of the switch while trying to put window up it works. I assume its worn and not connecting properly anymore. Good luck and hope it works for you too.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black
92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white.
