Old 04-28-2011, 08:05 AM
THE NEW GUY THE NEW GUY is offline
windshield Wipper goes beyond window edge
The wipper swicht is on "Normal" or "summer" possition but it does not make any change in the final possition of the blades. Do I have to check voltage in any wire of the wiper relay? where is it? please help! I do not want to brake the mechanism using the car the way it is now.
Old 04-28-2011, 08:53 AM
Geoff's Avatar
Geoff Geoff is offline
Send a message via ICQ to Geoff Send a message via Yahoo to Geoff
Re: windshield Wiper goes beyond window edge
Had the same problem. Just removed the nuts holding in the wipers when they were off, removed wiper arms, replaced them a little lower. Problem solved.
Old 04-28-2011, 12:08 PM
kwren's Avatar
kwren kwren is offline
Those Texans and their logical minds! Good call Geoff...
Keith
Old 04-28-2011, 10:42 PM
Re: windshield Wipper goes beyond window edge
Of coarse! but I would like to fix the problem it self. know why it is not working as it was suppose to! Any idea?
Old 04-28-2011, 10:48 PM
Do they sit in the same place in winter mode too? Are they too low or too high when they're off? And when they go up, so they go too far, too little, or the right amount?
Old 04-29-2011, 05:49 AM
dcarrb dcarrb is offline
Actually, the obvious solution here isn't necessarily a 100% fix. I've adjusted my wipers repeatedly yet the driver's side still occasionally strikes the A-pillar. The upsweep stopping point can vary by several inches. I've got the blades resting hard on the stops, yet once had a blade assembly snap apart after sweeping past the edge of the glass.
dcb
Old 04-29-2011, 07:26 AM
Geoff's Avatar
Might need a replacement wiper motor mechanism...I've got one for sale if that's the case.
Old 04-29-2011, 12:50 PM
I got a question about winter/summer mode.
I have never taken my wipers off of winter mode, why have them sit on the window if they don't have too?
Will I eventually break something If I leave them in winter mode?
Old 04-29-2011, 01:08 PM
You won't break anything. It is a feature so that when not needed, they sit lower for better aerodynamics and less drag. Then in winter mode, they sit on the windshield where the defroster can blast the windshield with hot air, and thus keeping the wipers from icing up.
Old 04-29-2011, 04:35 PM
In winter mode they sit on the window? I thought winter mode was off the window so I don't hit them with the ice scraper.
Mine live in the off the window position all year, good to know it wont break nothing.
Old 04-29-2011, 04:39 PM
winter mode so you can lift them up so you don't hit them with the scraper, and I think they rest slightly on the windshield so the defroster helps prevent ice buildup... I could be wrong... I would like to forget about winter now that it's finally warming up here. We just had more snow last week
Old 04-29-2011, 09:33 PM
SomethingElse's Avatar
word words wording
Re: windshield Wipppppppppppppppppppppppppper goes beyond window edge
more than likely they were not lined up properly when your cars windshield had been replaced.
Wipers
Eric
