Old 04-26-2010, 06:06 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Resinator
My argument is simply what I have been told. As for speaking with Magnaflow, I'm simply stating that you shouldn't trust some rep that might be reading something he just looked up on . I know how customer service works and more often than not, you have a college kid working in a call center or office making minimum wage answering your questions.
And Trev, the reason I said I have no clue what your talking about is because I have no clue what "self gratification" your speaking of.
Old 04-26-2010, 06:08 PM
Bonestock's Avatar
Bonestock Bonestock is offline
Nürburgring Warrior!
Re: Resinator
Bonestock, perhaps you did not read my post.
The letters in red say something.
Hugs and stuff!
I know what you said but TBH I dismissed it because there is no logical explanation.
The only possible difference your customers would have noticed is that their cars would be louder and the exhaust note may have changed. Any other reason would be from an obstruction, damage, faulty sensor, placebo effect etc.
Old 04-26-2010, 06:15 PM
Bonestock's Avatar
Re: Resinator
And I am telling you that its confirmation to what I have already stated by yet another source. If you don't want to believe Magnaflow's tech line that is on you. If you don't want to believe pretty much COMMON knowledge to certified mechanics, so be it. The information is here, if you want to pretend you didn't see it or stick your head in the sand... go for it.
BTW and what is wrong with being in college? I am a student myself. An old one, but student none the less.
Old 04-26-2010, 06:47 PM
Re: Resinator
Why waste time at college when you could be out flipping burgers at McDonalds for minimum wage.
Old 04-26-2010, 06:59 PM
Re: Resinator
Bonestock, I apologize if my post, #60 sounded harsh.
I had actually rephrased it and was waiting on Lady Di to approve it when the computer crashed.
Perhaps you noticed the "John" mentioned in the post.
He is a very well known and respected member here.
(As are Harvey and Trevor)
He swears that his son's SVX had lost power after the removal of the resonator and he, John is well noted for his excessiveness, and attention to detail.
And he has two SVXi to compare.
He is not the only SVX customer to tell me this, but untill I have hard #s, I can only report this as what I have heard.
On one of my SVX, (my Heavily modified Claret) the current exhaust is one that has no cats, and five resonators.
My personal definition of a resonator is a sound deadening device with a perforated center tube, surounded with a sound deadening material, with no obstructions to the flow of air.
A muffler is a sound deadening device with baffles, or parabolic chambers, or anything to divert/disrupt the flow of air in a chamber.
Anything that protrudes into the air stream, scalloped vanes, diverter plates, ect., to me constitutes a muffler.
On another note, usually the members on this Network gets along quite well.
We have very few personal attacks that are so common on other internet based networks.
Old 04-26-2010, 09:00 PM
Bonestock's Avatar
Re: Resinator
Nah I didn't take it as harsh. From our conversation a while back I know you know what you are talking about. As to the car in question we don't have any quantifiable data. The ol' butt dyno aint that sensitive.
If it is true that a minor change in the exhaust system made the car run poorly then there is something amiss elsewhere. Coincidence? Bad gas? Its impossible to know.
I don't know where this BS story of "if you remove something in the exhaust you need to replace it with something of equal shape and volume" got started but what a load of rubbish!
Old 04-26-2010, 09:02 PM
torxxx torxxx is offline
Re: Resinator
Originally Posted by Trevor View Post
You appear to be trying to contradict what I have posted, but say nothing contradictory.
I raced cars for years. I can assure you that based on lap times recorded when racing, running a straight exhaust on a standard production car, does not "make it drive like a fat girl being pushed in a wheel barrel." The lack of back pressure is of considerable advantage.
Maybe on a V8 it doesnt make as much as a difference. I've driven many 4 and 6 cylinders with completely open systems (small stock car classes that we have up here) and I've found with smaller engines, a fair amount of backpressure is something wanted more than not wanted. I'm not saying factory stock exhaust, but at least some form of restriction behind it.
Every engine and type of induction is going to have varied results. Like a diesel for example, if its turbo'd you want the biggest system you can get on it. Same goes to a degree with gas turbo engines. After the turbo you want a fairly open and big exhaust system. Supercharged same thing, you have all that air coming into the engine, and have to get it back out.
On a Naturally aspirated 4 and 6 cylinders, they fall flat on their face at mid range rpms with a completely open system. Putting something as simple as a glasspack in the way helps drastically at midrange. I've also discussed this with an old associate at work who's worked and ran one of the main GM repair dealer/repair shop up here. He's build hotrods for 35+ years and every hotrod he's build for people, even cars with big blocks in it have complete exhaust usually built with headers straight back to a performance muffler (like a flowmaster) on out, usually dual with or without a cross over or x pipe. He does that because that style of exhaust pulls the engines the best through the rpm band.
So either having: 1: Cats and no muffler no resonator, 2: No cats, no resonators and just a muffler, 3: No cats no muffler and a bunch of resonators ends up working better than nothing at all or a full system of straight pipe (as in no restrictions)
Thats what I was getting at. I posted my first post in the middle of the night, a lil cloudy minded so it didnt make much sense to me when I reread it today lol. And the fat girl in the wheel barrell reference was meaning they make a whole lot of noise with out a whole lot of movement
Old 04-26-2010, 10:13 PM
Freeman's Avatar
Unregistered User
Re: Resonator
Nah, nothing wrong with college student's. They have the patience and time to want to receive an education to get a good job.. It's taken me a while but I believe I'm going to go to college this year, finally..
The space to fill a space where it once was before was my doing. It was my simple way of putting what I thought was explained to me. Then again, I could have heard wrong or simply worded it incorrectly.. Oh well, lol.
Old 04-26-2010, 11:07 PM
Re: Resonator
I looked back at all my friends from High school that went off to college and graduated with a 4 year degree.. Over 50% of them are working jobs that they were qualified to work before the 4 years of college. (Mcdonalds, grocery stores, gas stations etc) 25% work in a profession completely different from what they went to school for and the other 25% actually got a job in their field of college degree.
I say become a mechanic and keep the world running!
Old 04-27-2010, 03:27 PM
immortal_suby's Avatar
Thread Killah
Re: Resinator
A glasspack is a straight through pipe, usually installed at the same diameter as the pipe it is connected to. It has glass packing in the enlarged section of the pipe, but not in the center straight through section.
Is it a restriction caused by turbulence? Or could the perceived performance gain be from the large volume area introduced in the system?
Locker Link
2015 BRZ Limited 6MT
Old 04-27-2010, 08:24 PM
Re: Resinator
The only conclusion which can be reached from the overall experienced quoted here, is that a production engine with valve timing and the like, designed to operate with a sound muffling system and therefore back pressure, will not run as sweetly without some back pressure. However on the basis of maximum power in a racing situation, mid range and sweet running is of no concern.
Old 04-27-2010, 09:12 PM
Old Fogey
Re: Resinator
.............And Trev, the reason I said I have no clue what your talking about is because I have no clue what "self gratification" your speaking of.
Yes, we believe you have no clue.
Glenn
Old 04-28-2010, 10:50 AM
kwren's Avatar
kwren kwren is offline
Re: Resinator
Glenn
No clue, Glenn?
I for one believes that Freeman, at the very least, has at least one clue
Keith
Old 04-28-2010, 11:31 AM
BoxerFanatic's Avatar
Re: Resinator
See, now this discussion re-affirms my wish for a dual-mode exhaust system.
Full equal length primary tube headers into collectors and low-restriction catalyzers (one for each bank)
Then into true-dual 2 or 2.25 inch pipe runs to either individual resonators, or a common 2-in, 2-out resonator box, pretty much parallel straight through, or maybe internal cross-over. (I've been looking at Stebro's Ferrari exhaust products... very nice... they run several 2-in-2-out muffler/resonator boxes, sometimes even 6 of them. More resonator length than pipe length in the exhaust system.)
Two pipes around the rear differential... hopefully two smaller diameter pipes will preserve a bit more ground clearance, as well... with each pipe diverging toward the outboard exhaust tip positions.
Where the current huge muffler is... I would use two mufflers, each same-side input and output, similar to a C6 corvette, or modern Porsche, or some sort of lateral criss-cross layout, if I have to use linear flow mufflers.
But the dual mode would be butterfly valves in Y-pipe junctions on each side. Closed would divert the exhaust through the muffler system, and back out to the exhaust tip.
Open, however, would dump straight to the exhaust tip, with the least amount of bending or impedance as possible.
The tips would be larger ovals than current, and set up with a merge of the inputs from the mufflers, or the direct valve on the same side of the car.
The valves would be electronically actuated, with a three position switch. Manual Open, Automatic, or Quiet (always closed)
Automatic would trigger the exhaust to open with the IRIS intake valve opening, above 4000 RPM. Possibly also triggered along with POWER mode even below 4000RPM with sharp throttle input.
Of course, all of that behind a nicely built high-compression NA EG33 engine with cams and other upgrades, and a STI/Spec.B 6-speed manual gearbox. A ~300 NA flat 6 horsepower that sings a sweet song.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
