Old 04-09-2010, 05:31 PM
smokin_dodge smokin_dodge is offline
Idle RPM
What is normal idling RPM for the svx and what is redline for the motor?
Old 04-09-2010, 06:33 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: Idle RPM
600 RPM plus/minus 100-150, I believe its 6800 redline but someone may correct me.
Old 04-09-2010, 09:12 PM
Re: Idle RPM
Mine idles at ~540 RPM. Something is telling me redline is 6500.
Old 04-10-2010, 02:33 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Idle RPM
IIRC the rev limit is slightly different for "in gear" and "in neutral". Idle speed depends on coolant temp and is compensated for a/c and power steering loads.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 04-10-2010, 01:47 PM
Re: Idle RPM
thanks for the input. the reason i ask is because when i modified my tachometer in my volkswagen to accept the svx's signal it says its idling around 1000rpm at idle - i know this is because the vw tach is setup to accept a signal for a 4-clinder but with the 6cylinder it sends 2 extra pules per revolution.
i cant find a way to fix this so instead im going to make a ratio to compare the vw tach to and need to know around where idle rpm is.
