Old 08-30-2007, 04:05 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
Slotted Rotor Install
Is there a preferred direction for the slots to go? At TDC (12 oclock) facing the rotor from outside of the wheel, should the slots be facing aggressivly like this: /// or should they be be facing the other way, like this: \\\ ?
Or does it matter?
Dave W.
______________________________
1996 Redd
Old 08-30-2007, 04:56 PM
JaySVX's Avatar
JaySVX JaySVX is offline
They should be not facing agressively, like the stock SVX wheels go. They should be facing the oposite way. Allows for better cooling.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 08-30-2007, 05:07 PM
I just put some on and they are put on like this: If you are looking at the wheel, (that was stupid) - anyway - if the wheel is turning clockwise, the slots would be \\\\, and if it was turning counter-clockwise ////. The would be moving the gas or heat out towards the tire. That might be wrong though. I will have to check my other ones.
Old 08-30-2007, 09:00 PM
The guys at StopTech made this very easy:
Stand facing the PASSENGER side front wheel
Salute the front wheel with your RIGHT hand
Now look at the angle of your hand, your fingers are pointing the direction that the slots should go.
On the DRIVER'S side, do the same thing only salute with your LEFT hand
Now wasn't that simple??
Old 08-30-2007, 09:50 PM
Originally Posted by svxcess
The guys at StopTech made tis very easy:
WOW John!
Those brakes look HUGE!!!
Old 08-31-2007, 04:24 AM
There seems to be a problem here. The left side has slots and is dimple drilled and the right side only has slots!
Thanks for the detailed explanation of the rotors John. I would not expect anything else from you.
Salute the car with the hand that you are on the side of. Left hand with left side of car. etc. This is easy to remember.
Old 08-31-2007, 05:45 AM
JaySVX's Avatar
Well think about it. The spacer supports between the two plates on the front rotors are directional. Centrifugal force is going to pull air out, however if your turning against those spacers, the air isn't going to be able to escape as efficiently. The backs, i would just put on the same direction as the fronts.
Old 08-31-2007, 06:02 AM
Actually Jay on a stock SVX the internal vanes are not directional, as they have strait vanes.
Old 08-31-2007, 10:33 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
The material I've read in forums as well as name-brand pages (StopTech, Baer, etc.) indicates that the direction of the slots is often inconsequential, so long as the vanes are appropriately oriented.
Regarding StopTech's AeroRotors: <linky>
Originally Posted by StopTech
The direction of the slots or hole pattern should not be used to determine what side of the vehicle to place a rotor. Different manufacturers may have different strategies for slot and hole patterns.
The only correct way to determine what side a directional rotor goes on is the internal vane direction.
Regarding the StopTech guys' "salute-ion" (oh, I slay me), that may very well apply to their SVX rotors, but their webpage shows that even their own brand varies.
Brembo says half 'n' half of that, too: <linky>
Originally Posted by Brembo
Which direction should the discs rotate?
It is a popular misconception that the slots or drillings in a disc determine the direction of rotation. In truth, for an internally vented disc, the geometry of the vanes dictates the direction of rotation. There are three vane types in use:
Straight
Pillar vane (comprised of many small posts)
Curved vane
The first two vane types are non-directional, and can be used on either side of the vehicle. The curved vane disc, however, is directional. A curved vane disc must be installed with the vanes running back from the inside to outside diameters in the direction of rotation...
...all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first.
It's probably safest to go by application, by brand.
Considering that the amount of gas that the slots are responsible for capturing is slight, that both ends of each slot are open to atmosphere, and that most of the way around, the slots are completely exposed, I'd follow the vanes first, manufacturer's guidance second, and (in indifference expressed by the components and their manufacturer) aesthetics third.
Naturally, as this defies some of the statements made in previous posts by a bunch of guys who don't just blindly hurl answers, I'm entirely interested in reading any opinions, quotes, or theories which parallel or contradict this one.
Old 08-31-2007, 09:20 PM
Actually since I only spoke of stock rotors I am free to agree with you and say a mighty,"HAHAA!".
So I will.
HAHAA!
My Big Rotors have axial vanes, and are "more" directional, but we won't get into that right now.
What was that quote about "You should not drink, and post?"
