Old 01-18-2007, 08:47 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Signs that you've had a REALLY bad day!
From the 2006 Reno Air Show!
2006 Steel Gray WRX TR (sold)
Old 01-18-2007, 08:51 PM
Took me a second to realize that gap was not designed into the engine.
Holy crap.
Old 01-18-2007, 11:58 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
car came it to my shop with fire damage and a similar engine condition except it was the rod that gave out blew a hole through the block sprayed oil every where and the hot exhaust manifold started the fire
- John
Old 01-19-2007, 12:00 AM
subi-crosser's Avatar
Now with more color
NOT your engine????
I have seen such things. I hope this is not from your engine!!
Jerry
Old 01-19-2007, 07:00 AM
Chiketkd's Avatar
Definitely not my engine. It's a Merlin and they run in the low 6 figures - USED!
Old 01-19-2007, 07:08 AM
mmmmm...Rolls Royce Merlin V-12...Ain't nothin out there that sounds like it.
We have one Spitfire here in Ottawa. There are only 44 left flying anywhere in the world. The only thing in the air that sounds better then the Merlin in that plane is the 4 Merlins in an Avro Lancaster bomber.
The Memphis Belle B-17 sounds pretty good too.
Old 01-19-2007, 06:16 PM
I beg to differ, you are having a really bad day when this happens 150miles off shore
Luckily there are two in the boat
oh, and I wear a size 13 shoe
Old 01-19-2007, 08:09 PM
Chiketkd's Avatar
Dayum Tom!
Old 01-19-2007, 10:23 PM
Good break,
That 6 cylinder crank, slows a classic harmonic fatigue break. Middle of the crank, starting at the oil hole drilling, to spread out to the webs. I guess it would have had the flywheel/damper combination replaced with the drive gear.
In a boat the engine runs at a constant speed, that in this case, looks like it was right on the cranks undamped resonance.
Have they checked the other engines crank?
Old 01-20-2007, 07:57 AM
They are seperate engines... It is not an issue with the crank but an issue with the harmonic... These harmonics weigh close to 75lbs and are filled with oil... The veins in the harmonic broke and all the oil moved to one side setting off a resonance frequency that the crank nor the block could withstand. After we took our spare block and did the good ol' strip n flip... we had our detroit puring once again
Old 01-20-2007, 05:14 PM
This is most certainly not a classic harmonic fatigue break. This type of failure involves torsional forces, which usually cause a break at, or close to a main journal. Alternatively, If the break is in a web, it will occur close to the crankshaft centre line.
In this case we have an off centre failure, which would indicate flexing due to an out of balance component, rather than simple torsional vibrations. There is no indication that the crack has started at the oil hole, but rather that it commenced at the inner edge of the bearing surface, where there is a sudden difference in structure. The outer looks torn away as the last part to break off, and shows a sudden occurrence rather than fatigue. Overall this evidence does not indicate a torsional component in the forces involved.
