Old 12-08-2010, 01:16 PM
rlutz rlutz is offline
Re: down shifting at 80 mph
Originally Posted by ...92LS-L View Post
You must disassemble the transfer clutch to obtain measurements...then order the plates. All clutch parts are "selective".
Afraid of that, thanks. Maybe it'll just be the TPS...
Old 12-08-2010, 04:59 PM
Normally just the solenoid, valve, and gaskets are enough.
Old 12-08-2010, 06:03 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
when it downshifts at 80mph, touch the metal at the bottom of the gear stick, or the side of the transmission tunnel. Does it feel hot? Your TCU may be going into overheat mode.
In overheat mode it uses lower gears and locks the torque converter to try and reduce the fluid temperature.
This started happening on our SVX shortly before the transmission failed.
Does your trans fluid look or smell burnt?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 12-13-2010, 04:02 PM
It was just the TPS!
I measured the voltage at 0.3V, adjusted it back up to 0.5V, and I've got my AWD back again. Also, it idles better, and is noticeably smoother under maximum acceleration. I'll be darned if such a simple adjustment didn't make a huge difference!
Not a bad car for 19 years old, when everything is working!
