Old 09-21-2010, 08:09 PM
Huskymaniac's Avatar
Uses the ignore feature
Brake fluid
Is DOT4 OK in the SVX? I assume it is. I am wondering if the esters in the formulation will help with heat extraction and reduce rotor warping.
Tony
Old 09-21-2010, 08:39 PM
Re: Brake fluid
I have used fully synthetic DOT4 in SVXi since 2001.
Old 09-21-2010, 08:54 PM
Re: Brake fluid
DOT 4 fluid is perfectly fine. Almost all cars manufactured by 2006 used DOT 4. I have been using the DOT 4 ATE Super Blue Racing Fluid in my polo for years. It exceeds all DOT 4 requirements and has a much higher wet (396° F) and dry (536° F) boiling point.
They make this fluid in both blue and gold. I alternate between them so it is easy to see when your brakes have been completely flushed by watching the color change at the caliper.
It is perfectly compatible with DOT 3 and they can be combined without problems.
What you don't want is the DOT5 (silicone) fluid. Incompatible with DOT3 and 4 and cannot be used with ABS systems.
Old 09-21-2010, 09:35 PM
Manarius's Avatar
Manarius Manarius is offline
Re: Brake fluid
If you want to reduce warping, cut off half the car.
3600 pounds of car and aggressive driving is what warps rotors.
-Jason
-Obi Wan Kenobi
Old 09-22-2010, 01:10 PM
kwren's Avatar
kwren kwren is offline
Re: Brake fluid
brake fluid = rotor warping
Keith
