Old 04-07-2014, 01:15 PM
devinb devinb is offline
wrx trans compatibality?
Just finished putting an 04 WRX five speed in my 92 and have a question on the rear diff.
I remember researching it a while back and found that the final ratio to the 04 wrx trans and the factory svx rear diff are the same and I can leave the diff in the car.
Can anyone share their knowledge to if this is true or not?
Thanks in advance.
Old 04-07-2014, 02:34 PM
Tireiron Tireiron is offline
Re: wrx trans compatibality?
That is correct. The SVX and the 04 5mt WRX both use a 3.54 rear diff. With the WRX 5mt your final drive is now 3.9 because of the center diff. The 5mt uses a 3.9 front diff with a 1.1:1 center diff which allows it to match the 3.54 rear diff correctly. Rock on.
Old 04-07-2014, 03:00 PM
Thank you for the help.
How ever I am now becoming more confused unfortunetly. I took apart one of the factory SVX rear diffs that I have and did the math and its a 37:9 which brings it to a 4.11 final gear ratio.
Old 04-07-2014, 08:35 PM
NiftySVX NiftySVX is offline
You must have one that has been converted to 4.44
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 04-11-2014, 03:20 PM
It's very possible the car had a different transmission put in and was not a stock SVX transmission.
Old 04-11-2014, 03:21 PM
How does that make any sense if he has a 4.11 rear diff?
Old 04-11-2014, 07:25 PM
40:9=4.44
37:9=4.11
39:10=3.90
39:11=3.545
