Old 01-17-2014, 01:46 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
ECUtune 1av1 question
Can you stick a 1av1 ECUtune modded ECU in a 92 AWD with a 4.44 swap...does it matter the swap was done?
THX
Old 01-17-2014, 03:23 PM
92 SVX 92 SVX is offline
Re: ECUtune 1av1 question
THX
For ecu yes you can.
Trans swaps are not a problem for the ecu
Old 01-17-2014, 03:28 PM
fasteract7's Avatar
Thanks for the info...
Old 01-23-2014, 08:34 AM
longassname's Avatar
Just some dude.
Like he said, the final drive ratio isn't an issue for the ECU. It is an issue for the TCU though. The final drive ratio is programmed into the transmisison control unit. The TCU uses it to translate the vehicle speed sensor 1 signal into a speed reading. The speed calculated from vss1 is one of the most important parameters the TCU uses. If you do not reprogram the TCU to match the new 4.44 final drive ratio then it will be 25% off in everything it calculates and looks up using that value.
Old 01-23-2014, 08:52 AM
What He ^ said.
The TCU chip for a 4.44 will make a big difference in how the transmission shifts.
I was driving the Version 3 TCU chip to PGH. and back the other day and IF I can get off of my frozen/icey/deathtrap road, will give an ipmression of how it does.
