Old 06-21-2012, 10:46 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
60-0 distance?
I just saw this 60-0 distance of 98ft for the SVX, in Wikipedia
I'm finding that hard to believe, since a STI with Brembos does it in ~110ft
how big of a lie are we talking about?! my guess is that it actually does it in 120-130ish...anyone tested that?
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 06-21-2012, 11:46 PM
Re: 60-0 distance?
Motorweek did a full report on the SVX when it came out in late 1991.
You can see the entire episode here
We are not talking a lie at all. According to the Motorweek road test, the 60-0 brake time was indeed only 98 ft. Here is a screen shot of that road test.
Old 06-22-2012, 12:10 AM
The NEWBIE
Re: 60-0 distance?
I have seen that, and I also have seen that other more recent review that talks about the braking performance being bad and needing an upgrade.
I personally can't see the SVX braking as good as these, specially being so heavy
or that's just me...thanks anyways
DIY FTW!
Old 06-22-2012, 12:24 AM
smc smc is offline
Re: 60-0 distance?
Believe it. Hell, check out the end of my video. 80 mph to 0 in just a tick over 100 feet. Stock brakes with stock rubber brake lines. Just some good pads. A good rule of thumb. If you lock up your tires, then you dont need bigger brakes. I had to modulate the brakes a good deal to keep from locking up.
http://youtu.be/6A7wND9oibk
Old 06-22-2012, 12:54 AM
jetboy's Avatar
jetboy jetboy is offline
Very Terrific Driver
Re: 60-0 distance?
I'm rarely in the pedal area where it actually bites but it does bite when you really kick the pedal. I've got EBC discs (vented all around) with greenstuff and when I went for a brake test I didn't even want to do a full emergency stop because it was very uncomfortable
"other reviews" probably complain about the brakes because they're not really so great for racing. Unless you really put effort into it, the SVX is not a racing machine (and if you turn it into one you will upgrade to much harder brakes).
It's got stopping power, maybe that explains the not so uncommon warping.
I got my girl,
I got my glass,
I got my car and
I'm ready to f...
Old 06-22-2012, 01:45 AM
The NEWBIE
Re: 60-0 distance?
I'm not one to do brake tests and I fortunately had to panic stop just once, and in that, I experienced 2 seconds of interrupted brake locking but I never imagined that it could be that good at braking...hell, I still have trouble believing it
that's a good explanation for the disk warping situation...
Thanks guys
DIY FTW!
Old 06-22-2012, 05:37 AM
Re: 60-0 distance?
The Myth of the Warped Brake Rotor
Having a clean mating surface and the wheels mounted and torqued correctly and uniformly are very important, but uneven transfer of brake material is the major cause of the vibration.
Old 06-22-2012, 06:11 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: 60-0 distance?
60-0 in 98 feet does seem awfully hard to believe. You're talking deceleration on the brink of 1.2g on civilian all-season tires? Don't fall too easily into YES OUR CAR WAS SO MANY AWESOME IT HAD MONSTER BRAKES BETTER THAN A 20 YEAR NEWER SUPERCAR ON STICKIES without doing the math.
I have no idea who Gil is, but the numbers posted <here (cars101.com)> 70-0 lean more toward 170. That would make a good share of sense when compared to the number posted <here (TampaRacing stats quoted)>, 134.
Old 06-22-2012, 06:18 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Re: 60-0 distance?
^ I miss Tamparacing..
Old 06-22-2012, 07:02 AM
Re: 60-0 distance?
The SVX thread on the TamponRacing site is a real hoot. Sooo much misinformation from those who did little research its ridiculous.
I like this quote :
"Car was designed by subarua with motor & all, but had some input from mclaren. Window design was from mclaren, supposed to be beneficial to get minimal wind buffer & rain in when having the window down."
No mention of Giugiaro
Old 06-22-2012, 07:21 AM
Re: 60-0 distance?
Tampa racing is full of 'tards. Packed, even. Highly un-recommended.
Old 06-22-2012, 07:25 AM
Chuckls's Avatar
Designated Asshole
Re: 60-0 distance?
Exactly why I miss it.
Old 06-22-2012, 08:15 AM
Re: 60-0 distance?
Old 06-22-2012, 09:55 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: 60-0 distance?
Car and Driver had the SVX stopping from 70 in 186 feet (not bad for the day) but not even the best in Subarus corner at the time. The Turbo Lego did it in 171 which was better than a Porkhaus 911 could do at the time.
Old 06-22-2012, 01:34 PM
The NEWBIE
Re: 60-0 distance?
but there is no way that 70-60 takes 88ft...one of them is incorrect, and based on the braking performance of modern cars, my guess is that the 98ft is not very accurate!
DIY FTW!
