#31
Re: Cut off and wrecked the svx bad
What all would I need to replace if I were to rebuild it besides seals
#32
Depends on what's actually wrong with it (if anything).
#33
lets say hypothetically it needs a rod bearing. I would get the bearings and what else to make it newish again? Piston rings? new rods?
#34
You'd also need rings, cylinders honed, block machined, heads machined, valve stem seals, and probably some more stuff. and just generally cleaning things up. Get some cometic headgaskets also. I don't think you'd need rods, unless one is actually damaged. Basically take it mostly apart and then take it to a good machine shop and let them have at it.
#35
pulled one of the head bolts out to find it covered in sparkly oil so its being parted for the good stuff and being junked for the metal.
#36
Got the new motor in and it fired up with no leaks. Took it around the block and can hear a rotational scrap from the middle of the car (driveshaft) maybe scraping a possibly bent heat shield? Hope so, just need to drive it some more to let the lifters to stop ticking, it isn't bad but from sitting so long they need a kick in the ass.
#37
Turns out the heat shield cracked and bent up touching the driveshaft. Just a slight clunk from the front guessing stuff loosened when it hit. Just needs the tires, rear struts,alighnment, and a well deserved bath.
#38
Glad you decided to save it. Nice going.
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#39
It was worth it. The car itself is in pretty good shape inside and out with and upgraded trans so it was a no brainer.
