Old 04-22-2012, 04:07 PM
Mr. Pockets's Avatar
Moderator
Saved for posterity: errors in FSM Section 2
While replacing rusty fuel lines on my SVX, I found that there are two diagrams in the factory service manual's fuel system section that are incorrectly labeled.
In Section 2-8, Fig. 7 (Component Parts, Fuel Tank):
The lines are labeled:
1. Delivery
2. Return
3. Evaporation
The correct labels are actually in a later diagram, Fig. 28. This is under the fuel pump removal chapter, and the correct order (following the same order as the first diagram) is:
1. Return
2. Evaporation
3. Delivery
Yeah, so the first diagram isn't even close. It has every single one wrong.
In the chapter on Fuel Tank Removal, Fig. 16's labels are at the very least misleading. I recommend seeing Fig. 32, under the Fuel Delivery, Return and Evaporation Lines removal chapter. That will make it much easier to tell the three lines depicted in that diagram apart. You'll have to take the rear seat cushion out, but chances are you already had to do that anyway.
I found these errors while replacing rusted fuel lines. Following the incorrect diagrams, my car would not start and I had no fuel pressure at the engine. I disconnected the line going into the fuel filter, stuck the end in an empty container, and saw no fuel when I cycled the fuel pump. Following the correct diagrams listed above, I had the car started in no time.
Hopefully this post helps somebody out some day.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 04-22-2012, 07:51 PM
Re: Saved for posterity: errors in FSM Section 2
Could you scan the figures in question and post them?
Old 04-22-2012, 08:48 PM
Moderator
I intend to, but I have to admit I may not get around to it for some time. I just wanted to make sure I got even the most rudimentary information down.
2005 Outback
END OF LINE
Old 04-22-2012, 09:24 PM
Thanks. I have several PDF copies of various FSM type things, but it might be difficult to figure out which one you're talking about exactly.
Is it this one?: http://www.phantomotaku.com/SVX/MSA5...uel_system.pdf
Old 04-23-2012, 09:17 AM
Old Fogey
Yep, pg 9, fig 7, first 3 part IDs should be renumbered;
3
1
2
Glenn
Old 04-23-2012, 01:01 PM
File attached for posterity.
Old 04-23-2012, 01:21 PM
Moderator
Yes, that PDF has all the diagrams I referred to in my original post.
2005 Outback
END OF LINE
Old 04-24-2012, 02:31 PM
Thanks guys - I will post the PDF along with the information already posted in the How-To Docs.
